Old 07-27-2006, 12:37 AM   #1
rlee02135 is an unknown quantity at this point
amp input wiring question
hello. i am wiring a kicker kx650.4 amp with two image dynamics IDQ10D4 V.2 subs.
i have a question...im going to tap into the rear door speaker's wires, so do i need a line level converter? i talked to radioshack and they said i could just crimp on rca plugs onto the speaker wire. is this true?
thanks
rlee02135 is offline   Reply With Quote
Old 07-27-2006, 12:47 AM   #2
Yevmeister's Avatar
Yevmeister is on a distinguished road
yeah you sohuld now have a problem, take a Rear Right, a and Rear Left, split, , one eng goes to the speker, second ends are going to the amp
Yev
R. T. F. M
Yevmeister is offline   Reply With Quote
Old 07-27-2006, 12:53 AM   #3
Yev
thanks...so using rca plugs on speaker wire is no problem, right? so whya do they sell that line level converter for 20 bucks? hwat does that little box in it do?
also, can i just tap into the right speaker wire to get a signal for both subs?
thanks
2004 C230K SS
Custom Silver CF Enclosure with 2 Image Dynamics IDQ10D4 V.2 Subs and Kicker Kx650.4 Amp
Old 07-27-2006, 12:55 AM   #4
thanks
sorry for the bad writing, im using my sisters laptop because my computer crashed and im not used to these tiny buttons.
2004 C230K SS
Old 07-27-2006, 01:30 AM   #5
Epon's Avatar
Epon is on a distinguished road
I wouldn't just snip-snip up the RCA's and splice another wire into them; the wires inside the RCA cables are tiny and gay to work with. I've seen an RCA adaptor that you can then "convert" the RCA male end to your own speaker wire.
Epon is offline   Reply With Quote
Old 07-27-2006, 01:46 AM   #6
im not just nsnipping up a rca cable. im taking these:http://www.radioshack.com/product/in...entPage=search and putting speaker wire into them and plugging it into the amp's input. do you think it will work?
thanks
2004 C230K SS
Old 07-27-2006, 01:50 AM   #7
walky_talky20 is on a distinguished road
You WILL need a line-level convertor. The signal going to your door speakers is "High-Level" or "Speaker-Level". Your amplifier needs a much "smaller" and lower power signal. It needs a "Low-Level" or "Line-Level" Signal.
A line-level convertor will take a speaker-level signal and give you a line-level signal that your amplifier can deal with.
Some amplifiers can take either speaker-level or line-level signals, but RCA jacks almost always carry signals that are line-level.
Peace.
walky_talky20 is offline   Reply With Quote
Old 07-27-2006, 02:04 AM   #8
Imy01's Avatar
Imy01 is an unknown quantity at this point
Okay, here's the deal...
From reading the thread it is my understanding that you want to know if you can take an active speaker wire, add the phono plug from radio shack to the end of it, and plug it into your amplifier. I'm pretty sure that this WILL NOT work. Why? Because there is power running through that speaker wire, and RCA cable is not made to have significant amounts of power in them.
Why do they sell line level converters, or AKA line output converts? Because "what that little box does" is it takes the watts out of the signal coming through the speaker wire. If you put pure speaker wire into your RCA inputs like you are proposing, you are going to either A) Fry your amp; or B) Get a distorted sound, or at least not nearly as good a sound as you would if you did it properly.
If cost is a problem, I would recommend using the Tsunami line output converter, available at Circuit City. Here's the link:
http://www.circuitcity.com/ssm/Tsuna...oductDetail.do
What you want to do with this is basically tap your speaker wire that is going into your rear door speakers, or better yet, if you have 6X9's mounted above the rear seats, tap into those. Run your positive from the left speaker to the positive on the line output converter, and run your your negative from the right speaker to the negative on the line output converter (or vice versa if you want). Then, connect RCA's from the line output converter to the RCA inputs on your amp. Be sure that after you verify your connections, you properly tune the gain on the amplifier as well as the line output converter, if they are improperly tuned you will get distortion.
I utilize a similar setup in my car and it works great for me....
Good luck.
Imy01 is offline   Reply With Quote
Old 07-27-2006, 02:05 AM   #9
Imy01's Avatar
Sorry walky_talky20, musta been posting same time as you, but we said the same thing anyway...
Old 07-27-2006, 01:25 PM   #10
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
Peace.
thank you...i was amazed at the bad advice that was given before this post.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-27-2006, 01:58 PM   #11
Shadow is on a distinguished road
New Ronco Watt Remover! I think you mean it attenuates the voltage of the signal.
Shadow is offline   Reply With Quote
bi-amp wiring question scott_fx Car Audio 5 05-13-2006 01:33 PM
Carnetix 1260 Wiring Question dante19 Power Supplies 5 03-02-2006 11:45 PM
HELP, Input Signal to AMP Power_nisse Car Audio 4 06-22-2005 12:35 PM
Quick AMP / Fuse Size Question tbird2340 Car Audio 2 06-07-2005 12:53 AM
Wiring harness question aegray Car Audio 9 01-10-2005 04:28 PM
