Old 07-27-2006, 01:24 AM   #1
hornyleprechaun is on a distinguished road
Limit to remote wire?
Is there a limit to how many things I can connect to my remote lead wire? I have running from my cig power source to my trunk. It worked fine when I just had it connected to my carputer and amp. I've since then added 1 more amp and the audiocontrol xover? Would it be ok to hook up all 4 of these things to the same wire? Thank you!
hornyleprechaun is offline   Reply With Quote
Old 07-27-2006, 01:28 AM   #2
Epon's Avatar
Epon is on a distinguished road
As far as I know, the remote turnon wire only needs a minimum amount of voltage to "flip" the internal relay on inside your amp/xover/whatever. I can't see this being an issue unless you're using terribly small or just ****ty wire.
Epon is offline   Reply With Quote
Old 07-27-2006, 02:11 AM   #3
Imy01's Avatar
Imy01 is an unknown quantity at this point
You should have no problems with this, Epon is correct: There is a minimal voltage running throug this wire. When I installed a second amp in my vehicle, instead of running another cable I actually bought a cheap power distribution block and just split the signal two ways...That worked great for me!
Imy01 is offline   Reply With Quote
Old 07-27-2006, 02:14 AM   #4
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
If you ae talking about the Amp Turn On Lead from your HU, it would depend. Some HUs can supply enough AMPERAGE to switch on many devices, but some can not, being able to supply less then half an amp. It all depends. You can try and find the specs for your unit, and keep under that, or just to be safe, use the amp turn on from the HU to flip a relay to make sure you have enough power. Also, make sure any wires you use are capable of handling the power.
If you are taking the amp turn on signal from an accessory wire from the car (Not the HU) then you should be able to supply enough power to power all your devices, assuming the accessory wire is capable of providing the power (it probably can supply an amp or two extra safely) and again, make sure your wire is thick enough for the amperage you must provide.
Michael
Wiredwrx is offline   Reply With Quote
Old 07-27-2006, 02:30 AM   #5
It is from an ACC wire, not a head unit. It would be 18 gauge wire, so I don't know if that would be enough for 2 amps, 1 xover and the computer?
Old 07-27-2006, 02:33 AM   #6
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
You should be fine.
Michael
Old 07-27-2006, 02:34 AM   #7
Imy01's Avatar
By ACC wire, if you mean that it is a wire that you have run independently of other components in the car, then it definitely had enough power for everything so long as it is split properly. The voltage for any in-car device that runs through the ACC line is minimal, almost negligible.
Old 07-27-2006, 02:40 AM   #8
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Just to be precise, it is AMPERAGE and not VOLTAGE.
Michael
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 01:38 PM
E46 BMW remote wire problem ayclens General Hardware Discussion 10 08-06-2004 12:40 AM
ME 2.0 Official Bug Reports phat_bastard ME Archive 67 01-31-2004 07:27 PM
Hooking OPUS to IGN wire?!? XxAndyxX Power Supplies 5 01-21-2004 07:21 PM
ps2 pelican remote w/ creative reciever & girder ShinkunoNamida Input Devices 0 04-26-2003 03:00 PM
