Old 07-28-2006, 03:02 AM   #1
bay350z is on a distinguished road
Exclamation M1-atx amp control
Anyone else have a problem with the m1-atx stop outputting 12v to the amp turn on pins?
Mine stopped turning the subs on. So I had to connect it back to the deck since i put the deck back in for now.
bay350z is offline   Reply With Quote
Advertisement Sponsored links
Old 07-28-2006, 06:37 PM   #2
no one else has the problem? Or have some ideas to why this is happening?
Old 07-28-2006, 06:47 PM   #3
volum3rider is on a distinguished road
I have never had this problem. One of the pins is ground and the other is +12v. You only need one. Are you connecting the right one?
volum3rider is offline   Reply With Quote
Old 07-28-2006, 08:03 PM   #4
FC3S's Avatar
FC3S can only hope to improve
jeez dude, u only waited 3 hours
but no, i've never had a problem with this either, u checked ur connections i assume?
FC3S is offline   Reply With Quote
Old 07-29-2006, 10:46 PM   #5
pancit175 is on a distinguished road
i actually had a similar problem with my M2-Atx.
With the remote line Not connected to anything the line tested as ~+12V. But when connected to the remote lines of the amps the voltage tested as barely existant. I attempted a current test and found that it did not have the proper current draw for switching on the relays, or as if there was some internal resistance in the circuit thus causing the drop in voltage.
But since I didnt really need the turn on delay, because i'm running optical with my alpine, I just hooked the remote line to a the Ignition line. Not to mention I also have an active push-button with a relay to turn on the amps so that it's not on only when I push it, and not blasting when I get in after I remote-start my car.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 07-30-2006, 07:21 PM   #6
Thanks for the input. For me it used to work. But you mentioned not enough draw, when i had it working, i had both the stock amp and my sub amp connected to turn on. This time was just the sub amp. But i tested with a multimeter and i get nothing now from those 2 pins. Soi guess that that part went bad or something.
Old 08-04-2006, 12:47 PM   #7
Monster is an unknown quantity at this point
Im a total newb when it comes to car PC, but not car audio.
Multiple amps off one remote turn on is a big no no.
Try this out:
1 30amp SPDT Relay
Connect: #87 to 12V Constant (use proper fuses on this)
#86 to 12v Remote lead off your PS
#85 to GND
#30 to Amps or other devices. (use proper fuses on this)
Hope this helps
Monster is offline   Reply With Quote
Old 08-04-2006, 01:06 PM   #8
Shadow is on a distinguished road
Monster, usually a picture helps someone to understand relays when you're referencing terminal numbers.
You don't really need to fuse #30. and #87 should be to switched power, not constant. This absolutely makes sure that the amps can't turn on if something decides to malfunction (except the relay) when the car's off.
Shadow is offline   Reply With Quote
Old 08-05-2006, 10:28 PM   #9
In my case the current draw wasnt enough to even run the relay that was triggering all the amps I have
PROGRESS:
Old 08-06-2006, 02:40 AM   #10
ramy_zohair's Avatar
ramy_zohair is on a distinguished road
Have the same problem. The current just isn't enough.
Final Touches
Car: 2002 Mitsubishi Magna EI
CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
ramy_zohair is offline   Reply With Quote
Old 09-16-2006, 12:56 PM   #11
proph's Avatar
proph is on a distinguished road
For the numbers... I'm another one that have amp turn on issues. Mine won't turn on a relay... just sad!!!
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 09-16-2006, 01:59 PM   #12
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
have you tried a solid state relay?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-17-2006, 07:52 PM   #13
not a bad idea. maybe a switching transistor circuit if one were so inclined
PROGRESS:
Old 09-18-2006, 09:47 AM   #14
miztahsparklez is on a distinguished road
i had a BOSCH SPDT automotive relay kick my amps on with my old m1atx.. one pin was 12v+ and the ground coil was tapped from a different ground wire from one of the molex connectors. worked perfectly, though the amps stayed on until the system turned off, but that was about the time you opened the doors so it was sorta like having a car with a radio that plays until you open a door.
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
miztahsparklez is offline   Reply With Quote
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 02:45 AM
M1 ATX issue VitalRyan Power Supplies 4 01-02-2006 12:07 AM
How to control an AMP with dual input kingtut Car Audio 16 09-02-2004 11:16 PM
Could a Pre-AMP be used to control 2 audio source to AMP kingtut Car Audio 6 09-01-2004 05:09 AM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 02:42 PM
