The MP3car.com Store
Thread Tools Display Modes
Old 07-30-2006, 01:27 PM   #1
Vehicle: 97/Mustang
My Photos: (0)
Amp and sub wiring question
I've got a rockford fosgate P5002 2-channel amp pushing 2 Alpine SWS-1022D dual voice coil subwoofers that are 2ohms per coil. Does anybody know the best way to hook these up so my amp doesn't overheat? The amp pushes 250Wx2 at a 2ohm load per channel and 500Wx1 at a 4ohm load bridged. I was wanting to run both channels but most diagrams show mono configuration. Please help. Thanx Rip
rip48 is offline   Reply With Quote
Sponsored Links
Old 07-30-2006, 01:43 PM   #2
Jahntassa's CarPC Specs
Jahntassa's Avatar
Vehicle: 2003 Pontiac Vibe GT
My Photos: (0)
With those coils, there's no way to get it 'mono' at 4 Ohms, so the only thing you could really do to get anything out of it is wire down to 2 Ohms (wire the subs so each one shows as 4, then wire down to 2), but then you only get 250w.
You really need a monoblock amplifier, or if you got the subs recently, return them for the 4 ohm coil version so you can wire the two subs to 4 Ohms.
Jahntassa is offline   Reply With Quote
Old 07-30-2006, 04:25 PM   #3
Vehicle: 97/Mustang
My Photos: (0)
What would bridging it mono and wiring the subs in a series do?
Old 07-30-2006, 04:38 PM   #4
Jahntassa's Avatar
My Photos: (0)
If you wire the subs you have in series, that puts out an 8 Ohm load. Wiring the 8 Ohm load to your amp in a bridge will probably put out somewhere around 200~250w (guessing).
The only ways you can wire those two subs together is either 8 Ohm load, or 2 Ohm load. So you can either do 8 Ohm bridged, or a single channel @ 2 Ohms.
If you need a way to figure out how to wire it, this is a great resource: http://www.the12volt.com/caraudio/wo...igurations.asp
Old 07-30-2006, 04:54 PM   #5
Vehicle: 97/Mustang
My Photos: (0)
So to get the most out of my amp I need the 4ohm subs? I have it wired in a 2 ohm load now and the amp gets real hot real quick.
Old 07-31-2006, 10:12 AM   #6
My Photos: (0)
That's because you're overloading the amp. You could either get dual 4 woofers or single 2 woofers.
Shadow is offline   Reply With Quote
Old 07-31-2006, 06:41 PM   #7
Jahntassa's Avatar
My Photos: (0)
Exactly as Shadow said. Your amp is not meant to run bridged in a 2 Ohm load.
Sponsored Links
vB code is On
Trackbacks are Off
Will stock alternator provide adequate ampage? (CPU + Sub) Cadillac_LoungN Power Supplies 0 07-07-2003 01:52 AM
Me=Newbie: Do I need an amp? Strix General Hardware Discussion 6 06-28-2002 08:11 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
