Could be many things wrong, Start by taking it to a shop and having it tested. If it works check all connections, like the ground cable to start,(make sure the ground is touching bare metal. Not painted metal) then move on... also check the sub's terminals, I had a pair of subs sit for a year and the cable that come out of the cone to the terminals came loose. Had to resolder the wire.
