Old 08-04-2006, 05:11 PM   #1
jaded_blade is an unknown quantity at this point
Unhappy opel/vaux corsa amp power source?
hey... just spent hours dispmantling my corsa trying to get the power lead from the engine to the amp but I cant find anywhere to take the lead from the car interior to the area under the hood/bonnet help?!
also, my amp only has two set of outputs, if i want to run 2 6x9s and a sub how should i rig it??
Thanks guys!
jaded_blade is offline   Reply With Quote
Advertisement Sponsored links
Old 08-04-2006, 05:48 PM   #2
Shadow is on a distinguished road
I'm sure Red will post her "this is a car PC forum" spiel.
Is your car an automatic? Does GM sell that car in the states? What kind of amp? Two sets of output meaning two pairs (4-channel) or two channels?
Edit: No GM doesn't but that's a cool little car.
Shadow is offline   Reply With Quote
Old 08-05-2006, 07:08 AM   #3
is a fusion four channel amp. i guess i need to wire the speakers in as usual and then wire the sub left + right - ???
the car is out in the u.s, but i dont know what name it goes by. and its manual. i just cant find anywhere in the metal panel behind the dash area that i can put the amp power cable through.
Old 08-05-2006, 10:00 AM   #4
MECP Buddah's Avatar
MECP Buddah is an unknown quantity at this point
if you can't find a suitable location you can drill a hole in the firewall just be sure that if you do this you protect the wire with a gromet to keep from getting a short.
Friends don't let friends install car audio.
MECP Buddah is offline   Reply With Quote
Old 08-05-2006, 10:05 AM   #5
Excellent use of punctuation, run-on sentences and capitalization.
Old 08-05-2006, 10:13 AM   #6
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
There is a rubber grommit in a hole behind the glovebox. Also accessible from behind the windscreen washer tank.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Amp has no power.. Help! Not Newbie. ziljin Car Audio 25 06-28-2006 10:59 AM
Power AMP from CarPC kiwiruss Car Audio 13 03-16-2006 01:52 PM
psu to power amp and speakers? qaz Car Audio 15 05-31-2005 10:27 PM
power? Subs w/ amp Jeffro Power Supplies 4 10-31-2001 12:50 PM
Here's an alternative power source.... A Boy and his Miata General Hardware Discussion 7 11-21-2000 12:44 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
