Quote: Originally Posted by
blkwrx
Wow, I gave you the answer in the first post. Taping the HU is the easiest way. Takes about 10min. If your not willing to do that then I would suggest running a switch. But its not going to be any less work than taping at the HU.
That's what I said!!
Well as for the speaker idea, I was thinking... This would degrade sq though.
Hook up the speaker wire to a rectifier (4 diodes in a diamond), then you would have something that would pulse sparatically but only at + voltages. Then you could hook that up to an inducer or sorts to filter out some of the craziness. Amplify that wire, and use it to power a relay to turn on the amp. Crazy huh?!
That would give you a rather weird option that will prabably turn off the amp if the volume is too low. It is an idea from what you suggested.
I have no idea if it would work
