Notices
Old 08-13-2006, 01:41 PM   #1
Sub Enclosure Slot port
Hi,
I have a JL 10 W7. The recommended ported enclosure for this is a slot. Does anyone know anything about this and ported enclosures in general, how do you know the size of the port and where to put it?
Cruizer is offline   Reply With Quote
Old 08-13-2006, 03:23 PM   #2
The port area should be listed. Rectangular area is calculated by width x height. You can put the port anywhere on the box but people usually put them on the baffle face.
Shadow is offline   Reply With Quote
Old 08-14-2006, 02:17 PM   #3
chuyler1's Avatar
If you visit JL Audio's website they will give you the exact dimensions for creating a slot port enclosure.
2003 Mazda Protege5 -- Clarion/DLS/Eclipse
Click here for install photos!
chuyler1 is offline   Reply With Quote
Old 08-14-2006, 02:36 PM   #4
_
just backing up what the others have said!
do you have a length for the port as well?
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 08-14-2006, 03:06 PM   #5
thanks for the response guys. I realise that jl have the dimensions for a slot port but I was trying to get an understanding as I am wanting to create a customer fit box. So is it the port length that is important or the port area (ie the size of the hole?)
Old 08-14-2006, 03:08 PM   #6
_
all of it.
I understand wanting to keep it all custom.
You really need to keep the port as they have recommended.
Jan Bennett
Old 08-14-2006, 03:45 PM   #7
OK so if the port area and the port length are both key, what is stopping me from making the port sqaure as apossed to a slot?
Old 08-14-2006, 04:28 PM   #8
_
I don't think there's a difference in going with a rectangular port v. a square port.
Make sure the face of the port is tapered to cut down on port noise.
From my understanding, a circular port will cut down on noise the most.
Jan Bennett
Old 08-14-2006, 08:52 PM   #9
You're supposed to not bypass a 3:4 ratio of the length of the sides. Try not to make the lenghs multiples of eachother and you'll be okay.
Old 08-15-2006, 12:04 PM   #10
3onDubs's Avatar
Here is a one-stop all you need to know on building box's forum:
http://www.caraudio.com/forum/forumdisplay.php?f=25
Good luck....
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 09-24-2006, 12:12 PM   #11
Another quick question a can't find a definitive answer to. In terms of port length. Is it just the length that is key? Can a port have an 180degree bend in it.
Old 09-24-2006, 05:13 PM   #12
_
yes, a bend is ok, just keep the same dimensions
Jan Bennett
Old 09-24-2006, 05:55 PM   #13
Just remember if you angle the port to measure the length down the midline of the vent.
RR forgets GPS port!!! eduardovdr Road Runner 2 07-17-2005 06:11 PM
Need help setting port number in the widcomm 4 driver malkalm PhoneControl 4 07-04-2005 05:38 AM
flush mounting slot loading drive residentalien Fabrication 4 12-29-2004 06:50 PM
anyone using FIR port on EPIA M board? stimps Input Devices 10 07-10-2003 11:02 PM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 09:48 PM
