Old 08-21-2006, 07:52 AM   #16
lol my bad i thought u meant 1500 watts to one sub since thats the peak, yea i kno iv thought about it but ill never put the volume high enough to destroy my ears, i just want to have the power there in case i ever feel like showin it off (when im not in the car driving it) or if i ever decide to jump into competitions (ill need way more power for that,lol)
TruPlaya26 is offline   Reply With Quote
Old 08-21-2006, 07:56 AM   #17
Quote: Originally Posted by MECP Buddah View Post
id recomend 2 DVC 4 ohm subs on a kicker 1200.1 amp, one of the salesmen i work with has this in his altima and hit 144.3 with it
so you think i should run both subs off the one mono amp? how would i connect 2 subs to a one-channel amp?
Old 08-21-2006, 09:46 AM   #18
The same way you connect a DVC woofer to a mono amp, different wiring configurations.
Shadow is offline   Reply With Quote
Old 08-21-2006, 09:55 AM   #19
find a 1500 watt @ 1 ohm mono amp you like and wire the 2 4 Ohm DVCs down to 1 ohm ( by putting them in Parallel ) then you will have rated watts for those subs
gt__1 is offline   Reply With Quote
Small Car, budget complete setup advice Scouse Monkey Car Audio 16 07-18-2007 08:10 AM
need advice on system type - ITX or ATX craigj Newbie 2 09-18-2005 10:03 PM
Carputer Advice Needed (My Plan) phatpaul Newbie 9 07-07-2005 04:29 PM
Another newbie looking for advice on hardware cid_mcdp Newbie 2 06-29-2005 10:47 AM
Advice Needed EBFoxbat Car Audio 14 11-22-2004 09:05 AM
