The MP3car.com Store
Thread Tools Display Modes
Old 08-26-2006, 12:23 PM   #31
My Photos: (0)
There's another saying: You can't polish a turd but you can chrome it.
Shadow is offline   Reply With Quote
Sponsored Links
Old 08-27-2006, 11:28 AM   #32
Vehicle: 02 Subaru Impreza WRX
My Photos: (0)
Quote: Originally Posted by Tidder View Post
Oooh no, I beg to differ. I've hurt myself by just screwing with a 12v lead for a stereo and accidently touching my arm to my ignition switch. And that's just with my hands. I'd hate to see what it would do to my tongue. I know it's not enough to kill, but it'd hurt like a some*****.
EDIT: Hey shadow, if you're so sure, do it. Make sure to get a friend to video tape it.
Then why can I grab the + and - terminals of a battery and nothing happens. If your arm is sweaty then there is something to conduct but if you stick a + lead on your tongue and touch the chassis I would think you would be fine as long as your not covered in sweat or drenched in water. Still not going to try it though
blkwrx is offline   Reply With Quote
Old 08-27-2006, 12:01 PM   #33
Vehicle: 1999 Saturn SL2
My Photos: (0)
within that lies the problem, grabbing both terminal is introducing two point of resistance, IE your hand on the positive is point 1, and your other hand on the negative is the other. Sticking either a ground or positive cable in your mouth (damn that sound silly when i read it) reduces the resistance in one of those points, making the other more capable of transferring current with a higher resistance.
... class dismissed, homework including self experiment with documentation and video feed on youtube due tmm morning on my desk.
::EDIT:: but on a serious note, if you want to use truck boxes, your biggest means of making them work is having them thin, but extending left and right of the sub enough to reach your required enclosure space for that sub. That may or may not mean dropping down to a single 12"... depends on how much space you have in the cab behind your seats, and how much space the sub needs to breathe.
After all that is in check, if it still doesn't sound good, do like others have said and make sure things are in phase (positive to positive, negative to negative... unless your bridged, then follow what your amp's guide says should be used as the positive and negative in bridged mode). Also make sure your driving them with matched ohms (aka if thier dual 4 ohm voice coils, and you have them connected in parrallel, make sure your amp is capable of putting out 2ohm on the channel that sub is connected to) And no you cannot bridge the amp and connect both subs @ 2ohm to the same set of terminals and suceed to get 2 ohm on the amp and sub side... ive seen that so many times. If you connect both subs to the same terminals and their already at 2 ohms, youve sucessfully made a 1 ohm load... something that only few amps will run at stable. If you want to do this, you either need to do one of three things: Either get a 1ohm stable amp (expensive), get an amp that has 2 channels that can be drive @ 2ohm stable, or wire your coils in series (positive to negative between the coils, then connect the remaining terminals to the amp) and the subs in parallel to get a 4ohm load for the amp, which quite a few amps can run bridged.
If all that fails to help, how about posting up your amp that your using, mabye we can help fidn you something of better quality that will suit your needs.
Killa200 is offline   Reply With Quote
Old 08-31-2006, 02:52 AM   #34
Raw Wave
Tidder's CarPC Specs
Tidder's Avatar
Vehicle: 04 Pontiac Sunfire (The Racer is dead...)
My Photos: (0)
I just wanted to say... you can chrome a turd, and yes, it's still a turd. BUT now you're the only one in the world with a chromed out turd.
And that's worth something.
Tidder is offline   Reply With Quote
Old 08-31-2006, 06:42 AM   #35
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
Except in the case of AudioBahn...where everyone and their dog has a chromed turd.....lol
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 08-31-2006, 10:22 AM   #36
Raw Wave
Tidder's Avatar
My Photos: (0)
I have an audiobahn amp... and it sucks.
Old 09-02-2006, 08:39 AM   #37
Vehicle: 97 rover 200
My Photos: (0)
i love honest people!
i have a directed amp and the bloody thing never works long enough to decide if its any good or not!
compaq evo n600c with docking station
7" widescreen
5.1ch sound card
DAB/DVB reciever
focal access 165 components
cerwin vega 2525 component
orion h2 12.2 subs
DLS CA50 5ch amp
directed 2400d monoblock
frugmonkey is offline   Reply With Quote
Old 09-02-2006, 02:42 PM   #38
FLAC is for flaccid
parksgm's CarPC Specs
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
Quote: Originally Posted by boomintrac View Post
its kinda like putting a bag over your head put a small wal-mart bag over your head and try to breathe. it will get a little tough after a while. then try it with a 50ga garbage bag you can just breathe and breath it will just get a little stuffy, meaning you can breathe more efficiently same goes for your subs for them to perform they need space.
Have you personally tried this? Is that why you can't use punctuation anymore?
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 09-05-2006, 04:23 PM   #39
My Photos: (0)
you will never get the same kick or sound in a truck as in a car
i find tens work nice in a truck
kiaz69 is offline   Reply With Quote
Old 09-05-2006, 08:18 PM   #40
boomintrac's CarPC Specs
boomintrac's Avatar
Vehicle: A little white wagon
My Photos: (0)
nope havent tried it and I choose not to use punctuation and is that all the help you can give ???????????????????
its called an example you know when you try to relate two different subjects so one understands what you are talking about it just states that it will be easier for something to breath in a larger open area you know small bag=small box large bag=large box but now if it were you id recommend a zip lock baggie and duct tape the $#@& out of it was there enough punctuation there for ya??????????
Aron
ZAPCO
boomintrac is offline   Reply With Quote
Sponsored Links
Old 09-06-2006, 10:20 PM   #41
My Photos: (0)
ok, enough trashing the cheap stuff, my customers love it, and i hate it for warranty issues. lol
but lets be real there are only a few companies out there that design, make and lay thier own circuits in their amps, same with sub cones, then they sell them to other companies and they put it in thier case.
kinda like puttin a turd in a chrome box.
some make modifacations to the board.
1stclasso is offline   Reply With Quote
Old 09-06-2006, 10:39 PM   #42
Phillie
Escalade182's Avatar
Vehicle: '03/Stratus
My Photos: (0)
...i didnt know a turd could be chromed....
but a ****ty pile of metal can be.
Escalade182 is offline   Reply With Quote
Old 09-06-2006, 10:40 PM   #43
Phillie
My Photos: (0)
a turd can be spray painted though!
Sponsored Links
Trackbacks are Off
FS or trade: (2) Rockford Fosgate 15" DVC subs PitchBlack98 Classified Archive 10 08-24-2006 10:42 AM
$44.99 Olympus S-HD-100 40GB External Hard Drive michael_16j Classified Archive 0 06-27-2006 09:14 AM
What Have you hit or missed on the freeway ???? will1384 Off Topic 29 03-05-2005 08:24 AM
hard drive probelms with sub woofer? gaZooGA Newbie 3 10-25-2003 10:03 PM
Hard drives and subs, can they play together? MobileSuit General Hardware Discussion 5 08-12-2002 11:10 AM
Sponsored Links
Ad Management by RedTyger
