At the moment the touchscreen is powered via the ISO connector where the headunit normally plugs in. Haven't tested another ground as of yet because I'm back at work today
Would grounding the chassis of the touchscreen do anything (as well as the normal GND cable on the ISO connector?
or would it need to relocate the GND on the connector block to somewhere on the body ?
Cheers
