The MP3car.com Store
Thread Tools Display Modes
Old 09-04-2006, 11:38 PM   #16
My Photos: (0)
ALRIGHT!!! Thanks!
my stock HU has preamp out, i just need to tap the wires to RCA. Do you think i need to solder every wire with RCA or just like twist them together?
is it that I will be able find all the speaker wires when i take out the door panel?
penny1jordan23 is offline   Reply With Quote
Sponsored Links
Old 09-05-2006, 07:19 AM   #17
Vehicle: 1999 Saturn SL2
My Photos: (0)
solder would be preferrable, best connection. Are you sure ther are pre-amp outs? If they are the wires that connect directly to the speakers, those need to be converted down into RCA's, as they are to powerful.
What do you mean by the second question, as i don't quite understand.
Killa200 is offline   Reply With Quote
Old 09-05-2006, 10:38 AM   #18
My Photos: (0)
i'm sure if i didn't misread this page
click here
ok.... actually i'm not quite sure wut wires should i connect to my amp.
i no that i need to connect power, remote and ground, also the RCAs..... then i thought there r also speaker wire. if i'm not wrong.... where should i find the speaker wire?
Old 09-05-2006, 02:02 PM   #19
My Photos: (0)
ah, seems your HU does have wires to tap for pre-amp outs. Sorry, i was assuming it didn't, as usually you don't get lucky enough to run into a situation like this. Follow that guide for your front and rear RCA's then like you had planned.
Old 09-05-2006, 09:25 PM   #20
My Photos: (0)
hey killa... can u do me a favor..... just repeat the steps on the installation of the amp.... i just want to make sure that i didn't miss anything
Sponsored Links
Old 09-05-2006, 09:58 PM   #21
My Photos: (0)
For the 4 channel amp?
Need to run two sets of rca cables from the HU to the amp for the front and rear signals. Need to run 2 sets of speaker cable to the front as well so you can connect your front speakers up (you can splice them where they would usually connect in the area the HU sits) As far as the back speakers, you can run 2 new sets of wires for them since your amp will be back int hat area anyways, would be alot more efficent than running wires to the front just so they run to the back again.
Then you need to splice off an 8gauge wire from our power distribution block in the trunk to your 4channel amp, and ground the amp either to a ground distribution block, or straight to the frame (best thing to do if not using a black is ground all equipment in the trunk to the same poiunt to kill the possibility of a ground loop). Also need to splice a P-ON (amp signal wire) from either the HU, or from the monoblobk amp which is connected to the HU already.
Old 09-06-2006, 12:29 AM   #22
My Photos: (0)
alright........
i think i know how to do the power wriing .....
the only thing i'm confused is the speaker cable, can u explain a lil bit more......
Also, i don't really understand what is this mean from the site i posted previously
"Take 2 1M to 2F RCA "Y" adapters. Chop the Male ends off. Strip back the outer insulation 1". Wrap the shield into a strand away from the center dielectric. Strip back the center dielectric 1/2". Now connect these directly to the wires below:
(Note: Each - is across form each + in the plug)
Right Front:
B4, Blue + (center of RCA)
B7 Red - (shield of RCA)
Left Front:
B1 Red/Blue + (center of RCA)
B8 Yellow - (shield of RCA)
Right Rear:
B6 Lt Green + (center of RCA)
B13 Purple - (shield of RCA)
Left Rear:
B3 Blue + (center of RCA)
B10 Pink - (shield of RCA)"
Old 09-06-2006, 07:33 AM   #23
My Photos: (0)
On the speaker wire. Your going to run a new set of speaker wire to all 4 of your speakers (front and rear) from the amp to the speakers. You'll need to run them form the amp in the back up to the front for the front speakers. You can either run the new wires to the HU location and splice the new wires into the wires that go to the door speakers (the door speaker wires would usually be connected to the HU) or you can run the new wires straight to the door speakers themselves if you wish. The back speakers will be easier since they are in the same general location. You just need to run the new wiring from the amp to those speakers.
On the HU: ""Take 2 1M to 2F RCA "Y" adapters. Chop the Male ends off...." is referring to those y splitters you can pick up at walmart, radioshack, or the likes. Ususally they have 1 male connection, and 2 female connector on the opposite end. They just want you to cut the male end off, and twist the shiedling (looks like braided wire, they use it as the ground wire) together to make a wire out of it, and then strip the colored wire from each female rca jack so you have bare wire. Then you will connect those to the pinout they gave you.
Old 09-07-2006, 02:58 PM   #24
My Photos: (0)
Alright, thanks alot for ur help. I will try it out this weekend
Sponsored Links
Trackbacks are Off
4 to 6 channel amp recomendation for 5.1 DD antimatter Car Audio 68 09-23-2006 06:44 PM
Wiring a 5.1 centre channel into front left / right amp lines Goines Car Audio 26 12-20-2005 06:23 PM
Memphis Belle 5 channel amp + Infinity Perfect 12" DVC - not sounding right replicant Car Audio 7 10-18-2005 02:53 PM
fs: 4 channel alpine amp EsKALad Classified Archive 11 07-27-2005 08:09 PM
Looking for opinions on Alpine MRV-F450 5 channel amp ShinkunoNamida General MP3Car Discussion 2 09-20-2002 05:57 PM
Sponsored Links
Ad Management by RedTyger
