Old 09-01-2006, 05:58 PM   #1
michaelrj9's Avatar
michaelrj9 is on a distinguished road
optima or compatible battery how long car off
Hi all,
Just was wondering is someone could give me a estimate time on how long I could run my carputer & amps with my car off with my optima yellow top.Just say a have the volume cranking and pulling about 3000 watts (amps are 3300 watts total) plus the inverter for the carputer.
I know I will not have it at full volume but just was wondering if I was at 3000 watts what time am I looking at?
Are we looking at minutes or 1 hour etc..
Michael
michaelrj9 is offline   Reply With Quote
Old 09-01-2006, 06:09 PM   #2
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
would completely depend on what kinda computer youre using.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 09-01-2006, 06:13 PM   #3
michaelrj9's Avatar
Shuttle pc with amd 2400 3.5 hard drive 7200 rpm etc power supply is 240 max inverter is 400 watt max.
(I was including the 3000 watt reference including the pc)
Michael
Old 09-01-2006, 06:32 PM   #4
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
how many amps are you drawing?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-01-2006, 06:40 PM   #5
michaelrj9's Avatar
Well if you go by my 3000 watt example. 3000 watts into 12v = 250 it would be about 250 amps.
Michael
Old 09-01-2006, 06:44 PM   #6
MySQL Error
scott_fx's Avatar
sorry, wattage claims from amp manufacturers are usually all over the place. I wasn't going to assume that the figures were accurate.
M10k
My Car Pc Install
Old 09-01-2006, 08:04 PM   #7
Terminal flasher
assuming 250 is correct... two hours? maybe 3?
03 Acura RSX Coupe
Old 09-02-2006, 08:41 AM   #8
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
10 to 1 this is peak power, NOT RMS, give us RMS specs with listing your car audio system. Peak doesn't mean anything.
Regarding how long...
I had a Stinger SP1700 battery in my car running a US-2000 amplifier (that's 2000watts RMS, NOT PEAK mind you) and I ran it for 4 hours with the car off, at about 90% volume to burn in the speakers (4 12" Eclipse 8700s).
Should give you an idea. However, this was a new battery as well with proper wiring, etc.
Older batteries will vary as well.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-02-2006, 11:41 AM   #9
Shadow is on a distinguished road
And seeing how he's using a deep cycle battery, it'll depend on when the thing was cycled last.
Shadow is offline   Reply With Quote
Old 09-02-2006, 02:44 PM   #10
michaelrj9's Avatar
Hi,
yes it is "RMS" I have 2500 "RMS" to the subs 400 rms to the components (100 rms each) plus the carputer.
It is a newer yellow top about 6 month old.
I know the manufactures inflate the ratings but that it what it is "supposed to be) LOL
Michael
Old 09-03-2006, 10:02 AM   #11
_
curious to know the brand and models of your amps.
Jan Bennett
Old 09-03-2006, 01:31 PM   #12
michaelrj9's Avatar
Orion 2500D
Orion 8004
0rion 12" H2 Sub into 1 ohm (2500 RMS)
plus 400 more for the components
From the Orion Website
2500D
Power Rating: 1000 Watts RMS x 1 at 4 ohms and = 1% THD + N. Signal to Noise Ratio: -59dBA (reference 1 watt into 4 ohms). Additional Power Output: 2500 Watts RMS at 1 ohm, 14.4V, = 1% THD + N
Michael
Dead Cell in New Car Battery chewiee General MP3Car Discussion 2 05-21-2008 07:54 PM
How long will my battery last? tmorgant1 Power Supplies 11 12-20-2005 01:05 PM
Installing car PC in 1996 Honda Civic PredatorCoder Newbie 8 08-18-2005 08:58 AM
Major Electrical Problems techy101 Off Topic 14 07-11-2005 10:47 AM
How long will the battery last? MFCN WarHammer General Hardware Discussion 17 11-04-2002 02:04 AM
