Old 09-02-2006, 01:13 PM   #1
patatoeswizard is an unknown quantity at this point
Angry sub is bumpin - but i dont want it to
don't have time to run out to the car to get exact specs so heres the run down-
on lower volumes (independant of the car engines status) my sub is putting out a loud bump.. bump.. bump.. - even when my head unit is muted - when i unplug the rca cables the bumping stops - but in my old settup i used the same head unit and this was never a problem - anyways the amp is used and relatively worn - and i bought cheap temporary wiring - is this usually a byproduct of emf or bad grounding or is there something more (ie bad head unit/amp) - when the volume is turned up some the repeditive bump bump bump is replaced by the actual bass to the music - any info would be much appreciated - if you guys need more info ill give details when i get back from work -thanks a bunch
patatoeswizard is offline   Reply With Quote
Advertisement Sponsored links
Old 09-02-2006, 01:44 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Sounds like a grounding problem to me.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 09-02-2006, 02:33 PM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
well, if you don't have time to get specs, are you going to have time to answer our questions? I only ask because I'd hate to try and help you out only to never hear from you again!
I'd start by reading this thread:
http://www.mp3car.com/vbulletin/car-audio-faq/79248-induced-noise-ground-loop-trouble-shooting-guide.html
If you unplug the RCAs and it stops. Chances are it's not the amplifier.
Check your RCA cables and make sure they aren't being put in any kind of a bind or being pinched in any way.
Otherwise, I'd suspect the HU going down.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-02-2006, 03:11 PM   #4
Tidder's Avatar
I'll have to jump in here with personal experience. I've seen this twice so far. I dunno if it's ground loop or what, but when the RCAs are plugged in, it's just a constant thump-thump-thump-thump (like techno!). Both times it ended up being a ground problem. Way we fixed it was grounding everything to the same location.
Weird thing is it would stop if the RCA's were unplugged from the amp.
That's why I'm so quick to call the ground a dirty rotten bas**rd.
Tidder
Try RevFE
Best Quote EVER!!
Old 09-02-2006, 10:56 PM   #5
thanks
wow thanks for the quick support - after work tomorrow i will reground everything - im glad someone else has heard of this - i just thought it was really strange because it really did resemble a techno beat - not a static noise - i will repost after i ground my heart out
Old 09-02-2006, 11:03 PM   #6
1stclasso is an unknown quantity at this point
to test the grounding for the rca's
cut a piece of wire, ground one end then (with the rca's plugged into the amp and playing) touch the other end of the wire on the outside of the RCA's. try that before disconnecting anything, of regrounding
1stclasso is offline   Reply With Quote
Old 09-03-2006, 02:08 AM   #7
FLAC is for flaccid
parksgm's Avatar
parksgm will become famous soon enough
What does that test? Since the RCA cables are only grounded through other components (and not directly), then grounding the shield would only tell you if there was a ground problem with one of the othe components they are connected to...and you would then have to solve by regrounding those connected components individually....so you might as well just do that first.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 09-03-2006, 09:59 AM   #8
_
This really sounds like something is grounding through the RCAs.
You can test this by picking up another set of RCAs, draping them across the seats, and plugging them in. This eliminates issues with pinched RCAs, etc.
Regarding manually grounding the RCAs. True. Some radios will actually ground through the RCAs because they aren't grounded properly to begin with. This is a lot easier to test than to start off by regrounding everything.
Jan Bennett
Old 09-03-2006, 01:27 PM   #9
troubleshooting
even it u fix the problems, its alway good to know the source for future installs, then sometimes u can change all the grounds and a week later the noise will come back, knowing the source is wise and less time consuming
Old 09-03-2006, 02:02 PM   #10
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
I had a the same problem with my setup. After about a month of use the problem started, I re-checked all my wires and found out that the ground for the powersupply had began to come loose, fixed that and the thumping was gone.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 09-04-2006, 06:47 PM   #11
Talking Victory
today before work i took your advise - first regrounded the head unit - didn't change anything - looked over the rca cable - they were fine - cleaned off the ground connection on the amp and regrounded that - tah dah - the rusty ground port on my amp was the problem - little cleaning - all better - thanks a million everyone
Old 09-04-2006, 06:50 PM   #12
_
glad you got it all worked out!
Jan Bennett
