Old 09-03-2006, 03:22 PM   #1
drPheta is an unknown quantity at this point
Wiring dilemma
As it is, we all say place the fuse closest to the battery.
What if we run 4AWG from the battery to the trunk, connect it to a dist block splitting it to 2 8AWG wires. How big of a fuse for the terminal at the battery? Do we install two fuses at the dist block for the 8AWG wires? If so, how big?
I'm powering a JBL GTO75.4 Amp, and a Carnetix P1900 with the two 8AWG wires.
drPheta is offline   Reply With Quote
Old 09-03-2006, 03:29 PM   #2
stealinfool's Avatar
stealinfool is on a distinguished road
Well, I'm using a similiar setup (as far as power consumption) and I'm using a 30A fuse in the engine compartment, 30a for the amp (my amp has an additional blade fuse on it) and 20a for the PC. The PC is the only one i'm not entirely sure should be that high, but it too has an additional blade fuse on the PSU.
DON'T PANIC.
Previous install pics in 2k3 S10
Project CarPc V2
stealinfool is offline   Reply With Quote
Old 09-03-2006, 05:03 PM   #3
SUVputer is on a distinguished road
Are you satisfied with from the JBL amp? did you install it? for how long have you been using it? I was planning to get it next week... wanted to see what were your comments
SUVputer is offline   Reply With Quote
Old 09-03-2006, 09:51 PM   #4
Shadow is on a distinguished road
Add up the fuses on all of your stuff you're going to be connecting and add 15% and you'll be good to go.
Shadow is offline   Reply With Quote
Old 09-05-2006, 11:44 AM   #5
albysure's Avatar
albysure
the fuse is there to protect the wire from burning up. so find the rating of the wire and use that fuse or a smaller rated fuse. if you run a line to the trunk you need to install a fuse less than 18" from the front battery before it gets to the rear.
98% complete. Couple of tweaks to the fabrication.
http://www.cardomain.com/ride/212327/14
albysure is offline   Reply With Quote
Old 09-05-2006, 12:51 PM   #6
JeffsGotMilk's Avatar
JeffsGotMilk is an unknown quantity at this point
That is what I would do.
JeffsGotMilk is offline   Reply With Quote
Old 09-05-2006, 04:08 PM   #7
albysure's Avatar
albysure
ok so what if your addition exceeds the power rating of the wire you're using?
i'm not saying you can't do this. just watch the rating of the wire
My headless wiring dilemma Okita Car Audio 4 09-27-2006 02:12 PM
Need Help - BMW's Signal Differential Speaker Wiring, Amps and SVEN4 lloydy Car Audio 8 02-14-2006 07:43 PM
Changing Head Units, Wiring Dilemma chmodx General Hardware Discussion 1 01-17-2006 11:15 PM
if you designed a vehicle's interior and wiring, how would you do it? stapan General MP3Car Discussion 7 12-26-2005 02:56 PM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 03:11 AM
