Old 09-04-2006, 04:43 PM   #1
bowwed is an unknown quantity at this point
Can you run a head unit without the battery/costant wire?
Basically, I've got an old Citroen ZX. I have been using a mates jvc cd player and have only had the black (ground) and red (ignition) cables attached and it has been fine. However I bought a new head unit, and all it'll do is let me insert a CD, and eject the CD. Not sure whether I need to somehow find a yellow (battery/constant) cable to plug in or what.
Any suggestions?
bowwed is offline   Reply With Quote
Old 09-04-2006, 05:01 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Strange....
It may turn on, but it might not save the memory presets on the radio. Clock would reset, bass and treble would reset as well.
Go ahead and hook up the ignition. You should have done it in the first place, might as well do it now.
Good luck!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-04-2006, 05:10 PM   #3
well this is the problem. I have wired in the iso cable from the wires I could find behind the head unit, but the only cables I seem to be able to find are the two already mentioned and speaker cables. How do I find another.
My old stereo used to work when the car was turned off, as does the lighter.
Perhaps I have the constant plugged into the ignition cable, but either way, shouldn't the HU still work like that anyway, or not?
Old 09-04-2006, 05:41 PM   #4
Killa200 is an unknown quantity at this point
you'll need the constant wire, as it does more than save clock time / presets. Usually all the ignition wire does is tell the head unit to "wake up", and the constant wire then takes care of the rest of the power requirements.
Killa200 is offline   Reply With Quote
Old 09-04-2006, 06:15 PM   #5
v8 scimitar's Avatar
v8 scimitar is on a distinguished road
Killa is right the more modern head units only use the acc really as a trigger circuit. They work more like car power supplies now where as older ones the BATT only kept the settings. Either run a line from the battery direct or you could wire the red and yellow together and put it to the ACC but it wont save your settings then
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
v8 scimitar is offline   Reply With Quote
Old 09-05-2006, 01:38 AM   #6
ah sweet, good idea! I'll try that out in a second.
cheers
iPod Head Unit Project Underway, Need Help Gathering Info! binglax09 Hardware Development 10 07-18-2006 10:24 AM
Hacking Head Unit CD with CD/DVD-ROM slot load drive? pktloss Hardware Development 7 03-25-2006 10:42 PM
Questions on a simple iPod audio input to head unit tenelson Car Audio 3 03-21-2005 11:56 AM
Help!! (how do you wire speakers to amp with no head unit?) mdray00 Car Audio 5 03-05-2005 05:15 AM
