Quote: Originally Posted by
vababyboi
Steps:
(1)Run power wire from battery to amp
(2) run rem wire from head unit to Amp
(3) Then run our rca cable form head unit to amp(same side as rem but opposite of power wire.)
(4) Next run speaker wire from am to 12 or car door speakers (depending on witch i was going for)
(5) I double checked to make sure my grounds on battery and the amp where both secure
What about the step where you run a ground wire from the amp to the nearest point on the chassis?
Remember to have the ground wire the same gauge as (or larger than) the positive wire.
vababyboi
The amp has power and my light comes on and fan is running but there is no sound output.
Check if the 'Protection' light is on.
If so, there could be a short in the wire that's going to your speaker/subwoofer.
