Old 09-07-2006, 10:31 PM   #1
vwgtipowr's Avatar
vwgtipowr is on a distinguished road
Terrible feedback, can't even hear audio...please help.
I'm not sure which forum to post this in, so hopefully someone here can help.
Today was the first time I actually tried to run the pc in the car.
here are the basic specs.
Power supply - m2-atx
Proc - P3 500mhz
mem - 256MB
HD - 40 gig 2.5"
CD - slim CDROM
I have a TM-868 touch screen monitor, that is also being driven from the 12v rail. My USB hub is NOT connected yet to the PC.
The problem I have is everything seems to work great, except for the fact that the audio is so quiet it is barely audible, and on top of it, there is a hissing/gurgling that is so lound on top of it, that it makes it useless.
I ran all the power wires down the left hand side of the car, and ran the signal wires down the center of the car to the center console. Power wire comes directly from battery, and the ground is ground to an existing ground in the trunk. I used to the dremel to make sure the ground was VERY clean, and ground away at it for a while!
The weird part is that the feedback I am getting seems to go with the changes in the display, or how hard the processor is working. The display also gets a flicker once in a while also.
THe TM-868 gets all signal, power and USB input through the single VGA connector. I had to use a 10' VGA extention from best buy to reach the front of the car from the trunk.
The Audio, is a headphone jack, that is split into left/right RCA cables. The RCA cables are also 10' extension that runs from the headphone jack on the PC (audio out) to the back of my head unit in the dash.
I have tried to be as descriptive as possible, hopefully someone has some helpfull suggestions, that can point me in the correct direction. I want to avoid having to rip the whole car appart again and rewire if possible.
I did make the mistake of not testing the audio in the house with the adapter and 10' rca wires. However I did use a 25' headphone extension wire when it was on AC power and it was fine. PC was tested with all other long wires.
Should the M2-Atx be ground to the battery? Does it matter? Should I ground the metal PC case to the vehicle?
TIA.
Car-PC progress meter (have PC set up in vehicle trying to workout feedback bugs)
vwgtipowr is offline   Reply With Quote
Old 09-08-2006, 09:14 AM   #2
vwgtipowr's Avatar
Unhappy
Anyone have any ideas?
Do people usually ground the pc case to the chassis?
Old 09-08-2006, 09:44 AM   #3
junglisitc is an unknown quantity at this point
yes ground the PC case to the chassis ground.
junglisitc is offline   Reply With Quote
Old 09-08-2006, 10:09 AM   #4
vwgtipowr's Avatar
Thanks I will try that first. I might try re-routing the audio signal wire away from the monitor wire too.
Is it bad practice to ground the PC-case to the power supply ground?
THanks
Old 09-08-2006, 11:00 AM   #5
You can never have to many grounds. PC case to PS is good as well. In a conventional PC case, everything grounds through the case to the powersupply.
Old 09-08-2006, 11:09 AM   #6
sciontC is on a distinguished road
and dont attach a ground to an existing grounding point. that also creates ground loops. reground that and ground your pc case and youll be set
2003 Ford F-250 7.3L Diesel Crew Cab
Pictures of my truck, hobbies, and more HERE
sciontC is offline   Reply With Quote
Old 09-08-2006, 11:14 AM   #7
vwgtipowr's Avatar
I am using a conventional case (mounted in the trunk).
I must just not have enough grounds? Or that is where I will start at least.
I will create a couple more grounds tonight and ground the case to the otherside of the trunk, and then also ground the case to the same ground as the power supply.
I get the same feedback whether I just touch the headphone plug to the case, or plug it into the case. Only difference is when it is plugged in there is faint audio in the background of all the feedback noise.
After all the planning and working on this thing, what a kick in the ***, when the big day came. I was playing an episode of entourage, and I could hear was crackling and hissing, no good.
Especially when the main reason is to play MP3s.
Old 09-08-2006, 11:15 AM   #8
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
junglisitc: yes, you can have too many grounds. For the same reason that sciontC is not correct in his statement.
You always want to try and attach to an existing grounding point when possible.
It makes things much easier.
Grounding to multiple points leaves you open to ground loops.
I think you have it backwards sciontC
to the OP - perhaps I just missed it, but can you describe your audio set-up? Your equipment and your method of getting sound to the speakers from the computer?
also, I'd read here for some good information: http://www.mp3car.com/vbulletin/car-audio-faq/79248-induced-noise-ground-loop-trouble-shooting-guide.html
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-08-2006, 11:17 AM   #9
vwgtipowr's Avatar
Ground loops?
Maybe that is part of my issue too then.
I have the power supply grounded to a ground point in the trunk, and there is a little ground already attached to it. It is a ground for the trunk light (which is blown btw).
So you suggest that I drill new holes, clean to bare metal, and ground to that?
Thanks guys I really appreaciate this.
I was so ****ed, nice to have people to help me work through this, and keep me sane!
Old 09-08-2006, 11:22 AM   #10
vwgtipowr's Avatar
also, I'd read here for some good information: http://www.mp3car.com/vbulletin/showthread.php?t=79248
I have a headunit that feeds the speakers in the car.
The headunit has AUX in (left/right RCA plugs).
The PC has audio out which is just the stereo type headphone jack plug.
I have a adapter from radio shack that plugs into the stereo headphone type jack and converts the signal to 2 RCA plug. I then have a 10' RCA wire that runs to the headunit and plugs into AUX input.
Currently I have one ground, and that is just the - PS wire. Case is not grounded.
Old 09-08-2006, 11:22 AM   #11
_
Yes, however, you should still try and ground to one point. Using factory grounds is not advised.
Jan Bennett
Old 09-08-2006, 11:26 AM   #12
_
so your HU has RCA IN?
what brand HU?
I've heard of people having big issues trying to use the aux in on a hu from the on board sound.
If you can, spring for a USB sound card, Go from the computer to that sound card then into the HU. See if it improves. I've seen people get them for as little as $20.
Jan Bennett
Old 09-08-2006, 11:46 AM   #13
vwgtipowr's Avatar
what brand HU?
Interesting link above.
I will have to try plugging my setup into my wifes Ipod (great idea), see if I have the same issues, if I do then I know it is NOT ground related, and maybe it is as you suggest with the RCA IN to the HU.
The headunit is a "DUAL" I purchased it from Bestbuy for $90. I kind of like it, it gets 3 times as many radio stations as my sony and slpine decks did. So hopefully it isn't an RCA IN issue with the HU. That would suck.
BTW, I used to own a black GTI VR6
Old 09-08-2006, 11:52 AM   #14
_
fwiw - DUAL is THE bottom of the barrel.
The fact that it gets more stations probably has to do with the install, not the hu.
let us know how plugging in the iPod does for you!
Jan Bennett
Old 09-08-2006, 11:58 AM   #15
vwgtipowr's Avatar
Yes, the DUAL is bottom of barrel, but I was trying to keep this project on a tight budget. Basically it is just being used, because it was the only thing at a reasonable price level that had RCA in. I would have used the existing alpine I had if it had some AUX input.
Mini-ITX boards RedGTiVR6 General Hardware Discussion 112 04-29-2009 09:08 PM
FS: Near-complete audio upgrade for E46 BMW w/stock headunit (NIB) GeddyT Classified Archive 11 06-16-2006 07:28 PM
Xenarc with Sirius audio issue - headless amp mymatrix Car Audio 2 06-01-2006 09:10 AM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 05:04 PM
Who wants an Audio Forum on mp3car.com? Banderon Mp3car Forum Suggestions/Comments 25 04-15-2004 10:19 AM
