My suggestion is to burn slower. The problem that you are experiencing has to do with the sensitivity of the CD Laser in your stereo. Burning slower makes a "darker" and more distinguishable "mark" on the disc - making it easier to read. Slow it down and use good quality media (Verbatim, TDK, etc) and you will have a much better chance of success.
I usually burn at 8x, but I have had a cd player that would work with discs burned at 2x, but not with discs burned at 4x.
You can also try using a different CD-Burner. Some more expensive burners (Plextor, Pioneer) tend to work better, although any change in media or hardware could do the trick.
Good Luck.
** Denotes an "in car" post
In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
