Old 09-08-2006, 05:25 PM   #1
wafflestew is an unknown quantity at this point
RCA to SPEAKER wire
hey guys; I know this isn't actually Car audio related, but you all seem pretty knowledgable.
I have a sub woofer (not powered) for a home audio set up.
The inputs for this Sub are strictly Speaker Cable.
the Sub outputs on my reciever are strictly RCA.
is there a way to convert RCA to speaker wire? I was thinking about getting a High Low adapter, but I believe that they only work one way (speaker>rca) rather then what I'm looking for (rca>speaker)
any thoughts?
I had an idea, maybe I can cut and splice input/output cables on my hi-low, but I'm not sure if it would take...
wafflestew is offline   Reply With Quote
Old 09-08-2006, 06:32 PM   #2
ARCTiC is an unknown quantity at this point
No no, the speaker you own is NOT amplified (passive), it is a normal speaker, the RCA output on your receiver is "0watt", that means you need an amplifier + a crossover (to cut the frequency, if it isn't alreay into the subwoofer) b/w your receiver and your subwoofer.
ARCTiC is offline   Reply With Quote
Old 09-08-2006, 06:55 PM   #3
rats. how much would a ****ty crossover-amp run me (I got the subs for free, so I'm not looking to pump money into this.)
Old 09-08-2006, 07:00 PM   #4
Eternalodyssey's Avatar
Eternalodyssey is on a distinguished road
Shouldn't this be posted in the "General Hardware" section?
Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
IS JACK BAUER GONNA HAVE TO SMACK A *****?
Eternalodyssey is offline   Reply With Quote
Old 09-08-2006, 07:19 PM   #5
I guess it could, but then the same could be said it being posted here, no?
Old 09-08-2006, 08:58 PM   #6
ATXaccord05's Avatar
ATXaccord05 is on a distinguished road
you need some kind of amp. depending on the impedance of the subwoofer, you'll choose your amp. (you can use a multimeter to find that), from there you need to find out what kind of wattage your subwoofer will handle. honestly, you're probably better off just getting a subwoofer meant for car audio.
ATXaccord05 is offline   Reply With Quote
Old 09-08-2006, 10:07 PM   #7
this is for my home reciever... and what's a multimeter?
Old 09-08-2006, 10:08 PM   #8
It depends of your sub wattage, but usually the home-video systems (as you're using i guess) uses an active subwoofer (it is powered and it contains the appropriate adjustable crossover and amplifier) ...they doesn't costs so much, if you have an entry level audio system, you would spend $50 for a cheap active subwoofer, that is less than buy an ampli and a crossover, and invest time to have it working.
Old 09-09-2006, 03:26 PM   #9
redls1bird's Avatar
redls1bird is on a distinguished road
This is the FAQ section, Its only for FAQ replies, no open posting... expect this thread to be moved by the end of today.
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
redls1bird is offline   Reply With Quote
Old 09-10-2006, 04:26 PM   #10
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Thread moved from FAQ Emporium.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Convert Speaker Wires To RCA? QuickSilver2005 Car Audio 33 10-23-2006 01:19 PM
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 01:38 PM
RCA to Speaker wire? greenglo General Hardware Discussion 3 02-16-2004 03:20 PM
How to wire a 4 spkr system with 2 speakers coscar Newbie 3 02-15-2004 10:57 PM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 11:58 PM
