Old 09-09-2006, 08:09 PM   #1
ESCDMA is an unknown quantity at this point
RCA output
Hi to all members, Pls give me some info about the RAC output, I have HU DEP-P8650 and the 3 RCA output is 6.5V, my Amp is MRD-M605 and the input level/gain is from 0.1mv up to 8v. I am new for the car audio setup, I need ur help to set my Amp, how many volt is the best setting to this amp. chers!!!!
ESCDMA is offline   Reply With Quote
Old 09-09-2006, 08:26 PM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
check this out:
http://www.icixsound.com/vb/showthread.php?t=27819
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-10-2006, 09:08 AM   #3
RCA Output
Hi Scott, thank u very much for ur help, now I set my Amp gain in a very best setting, now I can not heared the clipping, There was a lot of clipping and I try many things to do to remove that clippings, in the first place i used gage 8 power cable and my freind said my cable is very small to my amp, instead to buy a gage 4 cable, I bough another gage 8 and run it again together with the old one. But the clipping is still there because I don know how to set the gain, I though is if u put in the lowest Volt should be better, but when i hook up the volt metter as u said i saw the execieve current volt coming out. Actualy I already have test tone CD coming from my freind but I don know how to use it,( ''MY DISC'' The Sheffield / A2TB Test Disc ) now I know how to use this, Thank u again Scott CHERSSSSSS!!!!!
FAQ: Connecting your soundcard to a Volkswagen Monsoon Amp kbyrd The FAQ Emporium 88 09-04-2009 12:32 AM
Is all coax/optical spdif output created equal? Choser General Hardware Discussion 26 12-19-2004 03:48 PM
VGA vs RCA & Touchscreen vs other integsrtite LCD/Display 3 12-02-2004 07:07 PM
tank circuit - what output do I need? maxcosity Power Supplies 16 06-03-2003 05:00 PM
Sound Card With RCA Outputs? gguy General Hardware Discussion 5 12-03-2000 01:08 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
