Old 09-11-2006, 10:29 AM   #1
Madeye is an unknown quantity at this point
Exclamation Why do my amp switch off when I drive???
In my Uno I have 2 x 12" 1000w DVC Pioneer subs (to see what they look like go http://www.howhotismycar.com/?i=4470) connected to a 1200w 2 channel Starsound amp (both subs bridged to one channel) + 2 x 500w starsound 6x9's connected directly to my Wharfedale Mp3 frontloader. When I installed my sound it played perfectly for about 2 months, but now the problem is that when the car stands still and idles the sound plays perfectly at high volume, but as soon as I start to drive, it goes soft and most of the time the subs hardly play just the 6x9's play normally. People told me that the amp is too small for the subs and overheats (that's somewhat true, because the amps gets very hot), but why doesn't that happen when the car isn't driven??? Someone also told me that it's my altinator regulator. Can someone help me with advice, before I have to spent unnessacery money.
Madeye is offline   Reply With Quote
Advertisement Sponsored links
Old 09-11-2006, 10:54 AM   #2
Killa200 is an unknown quantity at this point
sounds like the addition of your aftermarket audio has taken its toll on your voltage regulator circuit on your alternator.
Which model Starsound amp do you have installed?
Killa200 is offline   Reply With Quote
Old 09-11-2006, 10:56 AM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
have you checked your grounds?
I'm not experienced with the brand of amplifier, however, after a quick google, they look extremely generic. usually meaning they are a knock off and have much lower quality components.
also, to have a set of 6 x 9s with a claimed power rating of 500 watts is a bit over the top and quite honnestly, difficult to believe.
I'd venture to bet that your equipment is having problems doing it's job. Double check all of your grounds and make sure they are 100% solid and are making a good connection.
Do you have any problems with any other components in the car? any other electrical issues?
If it's JUST the audio system giving you problems I wouldn't think it would be the alternator.
How big is your alternator? Have you upgraded the big 3? are you still on the stock battery? how old is the car? how many miles?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-11-2006, 11:01 AM   #4
Red brings up some good points after i took a visit to the amp's site. The company does look a bit on the 3rd rate side....
::EDIT:: On your amp, when things go "quiet" Have you had a chance to pull over and look at your amp to see if its going into protection for some reason?
Old 09-11-2006, 11:09 AM   #5
Shadow is on a distinguished road
Nobody's seen the obvious answer yet: Your amps switch off because you touch yourself at night.
Right, said Red.
Shadow is offline   Reply With Quote
Old 09-11-2006, 02:52 PM   #6
Focus_Dan is on a distinguished road
Right, said Red.
What???
Focus_Dan is offline   Reply With Quote
Old 09-13-2006, 06:19 AM   #7
Thanx. I found my problem: My grounds. The one connected to my amp was connected onto my back shock. As I started driving the shock moved and with that I lost my ground. I now connected it by myself to the car directly. The guy that did my installation for me was actually very stupid. Thanx for all your advice...
Old 09-13-2006, 08:35 AM   #8
There's usually a rubber bushing on the rear shock. That's why Red always recommends to not use anything factory as a ground.
Old 09-13-2006, 09:46 AM   #9
_
:d
Jan Bennett
Old 09-15-2006, 05:10 AM   #10
Go Red, you clever child!
Old 09-15-2006, 05:28 AM   #11
I have another question... What amp can my subs handle? I mean what is the best size amp for my subs 1500w, 2000w... I wanna buy a 2000w Targa amp, but will there be a difference in loudness if I replace my 1200w starsound amp. Will the amp waste my subs, isn't it too big??? What is the limit for my subs?
Old 09-15-2006, 06:42 AM   #12
_
If you set your gains correctly, you will not over power your speakers, even with a 10,000 watt amp.
You need to find out what the RMS rating is on the subs that you are running and find an amp that is as close as possible to that rating. That way you aren't paying for unused wattage.
I'll give you a hint, instead of falling into the trap of believing that more power is better, buy a better product to begin with.
Targa and Starsound are NOT good products.
Buy a higher quality product and you'll notice a difference in sound. I guarantee it.
Jan Bennett
Western Digital buyers beware! tj!2k4 General Hardware Discussion 65 11-26-2005 01:17 AM
MB870 & Slimline Floppy Drives McGreggor General Hardware Discussion 5 11-09-2005 07:32 AM
AMP wont turn ON!! HEELP! pdjafari Car Audio 1 10-15-2005 08:43 PM
2.5" drive help? IntellaWorks General MP3Car Discussion 4 10-03-2005 08:36 AM
External notebook hard drive help mtmsol General Hardware Discussion 4 04-18-2002 01:24 PM
