I need four channel output + line in. Possible with my setup?
Ok here is my problem. I have a four channel amp with four RCA inputs. At the moment I am using the onboard sound on my M10K clone. The line-out is currently going to my amp but I only get two channels obviously.
Now the M10K supports jacksense so I could convert the onboard sound so that line-out output the rear channels and line-in output the front channels. The problem with that is that I need line in because I use a Radio X-treme FM tuner and it outputs via line-out so it needs to be input somewhere in my system.
I also have a 5.1 Zalman USB soundcard but it doesnt have line in so I cant use it. When I have the USB sound plugged in the onboard doesnt work so I can have a mixture.
Is there a solution here that I am overlooking?
