Quote: Originally Posted by
swift_gti
Sorry I knew there was something I forgot!!
This is with no source connected at all.
It simply the Lilliput touchscreen (has its own amp built in) connected via the ISO connectors on my car to my standard speakers (2 sets of components)
Same when I tried the standalone amplifier - no source connected still got ticking - but I only got the whining with a source connected on that one...
I have searched but I only seem to find things about moving to a better earth point - but I've already sanded down the bodywork and used a self tapper to make a clean earthing point.
I'm at a loss to what I can try to fix this now!
K, I am no expert, but I will do what I can.
First, Do you get the whine with out using the "other/external" amp you mentioned. So, when just the Lilli built in amp is powering the speakers?
There are devices that are meant to go in the power wires to eliminate engine whine. You mentioned you used something, I just want to confirm that is the type of device you used, NOT ONE FOR THE AUDIO PATH, but the power wires. Also, can you try a different brand if in fact that is the type of device you used. You also might try putting the filter on the "accessory" wire in case it is introducing the noise.
It is possible that the quality of the internal amp is just not good.
Can you try powering the unit with heavy gauge wire directly from the battery, including the accessory wire for testing purposes.
Have you tried earthing the BODY of the unit. Maybe something in the car is causing the interference, and the Lilli is just not adequately shielded. Try wrapping the unit in aluminium foil (MAKE SURE NOT TO LET IT TOUCH ANYTHING WITH POSITIVE POWER ON IT) and see if that improves the noise.
Hope some of that helps.
Michael
