Old 09-17-2006, 08:33 AM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
USB DAC options
Hey all.
Seeing as how the USB DAC has become a popular option for some folks, I figured a thread listing the options out there would be beneficial.
I'd like to set it up much like the 5.1 amps with digital ins thread, and the mini-itx threads on this board elsewhere.
So show me what you have found!
http://www.wavelengthaudio.com/ - This is by far one of the nicest DACs I've found. However, the price will cause some people to nearly stop breathing I'm sure.
http://www.silverstonetek.com/products-eb01.htm
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-17-2006, 08:37 AM   #2
_
Seeing as how I'm sure there will be much debate and discussion regarding these DACs, I figured a few words about them from various sources might be beneficial to some.
What is a DAC?
From the Stereophile Forums talking about jitter and USB DACs as well as USB two way communications for error correction. VERY good read.
Jan Bennett
Old 09-17-2006, 08:48 PM   #3
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
well i guess i'll start.
this is the one i'm currently testing:
http://www.ecp.cc/HPDAC.html
we'll call it the 'douglas' hpdac. since this is a diy board you can use whichever components you'd like. I'm currently running burr-brown opamps and blackgate caps.
also... since it's a diy board you can wire it with female rca's to connect directly to your amp. This will give you a digital signal within inches (or less) of your x-over or amp. If you are going the x-over route you can also think about cracking that active x-over open and wiring the outputs of the dac directly to the inputs of the x-over.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-18-2006, 08:06 AM   #4
proph's Avatar
proph is on a distinguished road
I use the Silverstone USB DAC. It of course doesn't require a driver, just plug it in and it shows up as USB Speakers. You don't have to worry about turn on thump w/ most DAC's, as w/ the SS it doesnt turn on till it gets music to play. The DAC doesn't require in extra power... just a single USB cable will do comms and power. The sound is rich and clean.
The problem most DACs (that have problems) have is that of IRQ's. On my setup I have 8 USB 2.0 powers onboard and a add on card, along w/ the normal basic interupts. When I first connected the DAC to this setup I had cracking and popping... after disabling a couple things in the bios I've lost all but a slight crackling every now and then. The fix is usually changing the PCI latency or changing IRQ's for the device.
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 09-18-2006, 09:48 PM   #5
drPheta is an unknown quantity at this point
You can change the volume of the DAC using your front end, correct?
drPheta is offline   Reply With Quote
Old 09-18-2006, 10:20 PM   #6
proph's Avatar
Correct!
Setup:
Dynaudio 240GT
Zapco DSP6
ADS DAC
Old 09-19-2006, 09:07 PM   #7
jschrauwen's Avatar
jschrauwen is on a distinguished road
*clutches chest and reaches for phone to dial 911* j/k. Amazingly resembles the prices my brother charges for the high current tube amps that he builds.
*edit*
Would the average person/carpc system be able to discern the quality difference between an $84 Silverstone and a $195 HPDAC? I don't even want to try and get my head wrapped around the Cosecant, Brick, or Ultimate DPU.
1990 RHD JDM 300ZX TT 2+2 5sp T-Top
491RWHP / 18psi / 94 octane
jschrauwen is offline   Reply With Quote
Old 09-19-2006, 10:01 PM   #8
_
The average person can't tell the difference between a MP3 ripped a 128 and the true CD source.
However, it's like anything else in life. If it's something you are into, which we all have something, you know the differences.
When you live and breathe something nearly every waking moment of your life, you can tell a difference.
Jan Bennett
Old 09-19-2006, 10:28 PM   #9
proph's Avatar
If that was the truth it would be a shame.
Setup:
Dynaudio 240GT
Zapco DSP6
ADS DAC
Old 09-20-2006, 09:01 AM   #10
_
why do you think the iPod has become so popular? Why do you think there are companies making millions off of selling mp3s that are much less than CD quality?
it's because people don't know the difference and don't care to.
Try and find a music store online, where you can download music files in HIGH quality.
There was 1 that I was aware of, and even then, it wasn't 'HIGH' quality by many standards...
Jan Bennett
Old 09-21-2006, 11:35 AM   #11
XxAndyxX's Avatar
XxAndyxX is on a distinguished road
I'm using silverstone's EB01, and the sound quality is awesome. The only problem is you can't input through another sound card and output through the DAC... So no XM radio! It really sucks and I'm trying to find a solution.
There's a program called Virtual Audio Cable that may be able to solve this problem, but I haven't had the time to figure it out.
XxAndyxX is offline   Reply With Quote
Old 09-21-2006, 12:24 PM   #12
MySQL Error
scott_fx's Avatar
(lets keep this ontopic N00BS!!!)
M10k
My Car Pc Install
Old 09-22-2006, 08:09 AM   #13
proph's Avatar
Yeah yeah... I'm very aware of the latest trends. I dont think its a fact that most dont know the difference, its probably 90% that they dont care. Most are still downloading illegally, and the others are following the leader to ITunes.
I download mine from a Russian site that has high bitrate albums. You can chose the compression level of your download.
Setup:
Dynaudio 240GT
Zapco DSP6
ADS DAC
Old 09-22-2006, 08:13 AM   #14
proph's Avatar
XxandXx let us know how that works out for you. I was weighing my options (same boat as you w/ XM).
Setup:
Dynaudio 240GT
Zapco DSP6
ADS DAC
Old 09-22-2006, 01:08 PM   #15
MySQL Error
scott_fx's Avatar
bad link?
M10k
My Car Pc Install
Found a new USB dac! kingeorge36 Car Audio 169 01-04-2009 04:29 AM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
USB hub does not always initialize on boot d_sellers1 General Hardware Discussion 5 05-29-2006 04:41 AM
Powered Hub, Lots of USB Devices! Will this work? adamharrisuk General Hardware Discussion 4 05-15-2006 12:00 AM
Slot load, usb sound, fm/tv tuner, wifi, laptop and more dmcdlrn Classified Archive 13 04-25-2006 01:43 PM
