Old 09-18-2006, 07:12 PM   #1
tooby's Avatar
tooby is an unknown quantity at this point
popping noise
ok, i know this question has probably been addressed all over the place, but since I was having problems finding answers related directly to this I figured i'd ask.
firstly, I have a EN12000EG
A Silverstone USB soundcard
and an M2-ATX PSU
as well as a VOOMPC enclosure
I am getting a popping noise in all audio coming out of my carputer, I know it is directly related to the carputer and not any amp because when I play the radio (not connected to the carputer) I do not get any sort of a popping noise.
this is a pretty regular popping / snapping noise, and being an audiophile (which is the reason I went for a 3.1V preout with the SS) it sounds absolutely terrible. I have seen other people who have changed things in the BIOS to elminate this but this isnt necessarily a viable option, seeing as how the bios on that mobo is really......dumb.
I also have already tried a temporary grounding of the outside chassis of the case, didnt help at all, but then again, it wasnt a permanent type of grounding, just me touching a bare wire to the case, and the other end of it to a ground.
Any and all help is greatly appreciated, because i've spent around 1400 or so on this system and I cant stand the sound it is making. So thanks again, and if you have any other questions about my system specifics go ahead and ask
tooby is offline   Reply With Quote
Old 09-18-2006, 07:39 PM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
unplug all of your other usb devices (yes even the touchscreen) and see if it is still happening
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-18-2006, 10:59 PM   #3
mhickin is an unknown quantity at this point
I had this problem too..
What i found is that my power cables and audio out cables were too close together. The trick is to keep the Audio cables as far away from the power cables as possible.
What was causing it is the fact that currents running through cables can actually jump from one to the other (especially if there is thin insulation). So your problem might be that the cables are too close and the power is jumping to ur audio and screwing it up (NO u cant SEE it).. But yeh.. move them apart as far as possible. If they are apart, i dont know, but thats what was wrong with mine.
mhickin is offline   Reply With Quote
Old 09-19-2006, 12:31 AM   #4
tooby's Avatar
holy damn i hope thats not it, cause they are run together for a pretty way, and would be a ***** to move them apart. Though I wouldnt think that this would be it, because I did pay a little extra for some nicer cables
Old 09-19-2006, 12:33 AM   #5
tooby's Avatar
something I definetely didnt think about, I'll try it for sure
I'm also going to try changing some settings on the computer as well as changing an irq for a dac (dont know what it means yet but i intend to find out and do it, haha)
I'm gonna try all of these things out, and if those 3 things dont work, I might have to try what that other guy said an make sure the power and RCA cables arent run near each other, though of course I'm gonna try for an easier fix first
Old 09-19-2006, 04:02 PM   #6
ThE_KiLLeR is on a distinguished road
don't you also have noise while starting windows ?
as you'r running an usb soundcard..
ThE_KiLLeR is offline   Reply With Quote
Old 09-19-2006, 04:32 PM   #7
Will Albers is on a distinguished road
Power next to RCAs is a BAD thing regardless of the quality of wire. You need to do it right the first time when trouble shooting. Do you have alternator whine as well?
Will Albers is offline   Reply With Quote
Old 09-19-2006, 04:39 PM   #8
tooby's Avatar
I have actually never noticed any noise while starting windows, no, besides the normal ones that is, when the thing isnt supposed to be making any noise, i'm not getting any noise, even the cracking popping sound
Old 09-19-2006, 04:55 PM   #9
no noise while the car is running? Nothing that changes pitch with the rpms of the car?
Old 09-20-2006, 12:37 AM   #10
tooby's Avatar
no, no pitch change at all, no matter how high i rev the engine
Old 09-20-2006, 03:02 PM   #11
tooby's Avatar
ah, might have an irq problem then? well then mabye i can just install a pci usb hub, but what pci usb devices would fit into my case? (voompc case)
Old 09-22-2006, 08:27 AM   #12
proph's Avatar
proph is on a distinguished road
Its an IRQ issue for sure. Theres a couple DAC forums that go into the same thing. I've had the conflict and tested the DAC w/ the laptop (bringing the laptop to the truck) and it totally went away and actually sounded alot better. I changed a couple things at one time, so can't pinpoint it. A couple things that worked for others was changing the PCI slot (most of us dont have that option), Changing the PCI latency, changing your display properties to 16bit. I'll look for the writeup later today. We need to keep this topic hot for a definitive fix for the issue. Anyone wants to start changing IRQ's (Arghh)?
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 09-23-2006, 12:58 AM   #13
Prot is an unknown quantity at this point
Ground Loop Isolator--> eBay
doubt it it will address your problem but other people looking this thread might be looking for this solution.
Prot is offline   Reply With Quote
Old 09-23-2006, 01:37 AM   #14
tooby's Avatar
i'm good and ready to start changing stuff in the bios, as long as it dosn't fry anything. I recently installed all the completely up to date drivers, and it actually fixed a lot of the popping, but it is still there, and i know i can make it even better so i'm definetely still going to work on this
I've plugged my earphones into the dac to check if the popping was still there, it is, so the popping definetely isnt related to the rca cables being run with the power cables
Old 11-01-2006, 12:12 AM   #15
proph's Avatar
Hey I have mine fixed... I changed the dram timing from 533 to 400 and I haven't heard a peep yet.
Setup:
Dynaudio 240GT
Zapco DSP6
ADS DAC
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 03:36 AM
Speaker Popping Noise (delay circuit options?), Line Drivers to boost volume which 1? SuprchargdMazda General Hardware Discussion 9 05-26-2006 08:57 PM
Got rid of BUZZ noise!! bleunetizen General Hardware Discussion 3 10-30-2005 08:20 PM
Troubleshooting: NOISE RedGTiVR6 Car Audio FAQ 0 03-26-2005 11:31 AM
Finally got rid of the popping noise! XxAndyxX General Hardware Discussion 4 10-19-2004 02:24 PM
