Quote: Originally Posted by
EtoS
Well I got the computer in and working great. Only issue now is sound.... I have no idea how to connect the pc to the speakers. I have no experience whatsoever on how to do audio work outside connecting wires on my PC speakers and doing aftermarkets headunits in cars. I was told I'd need an amp but I have no idea how they work, what I'd have to get/do as far as connections from the pc to the speakers. As far as my goals in sound- just getting it working is fine. I don't need any incredibly high volume or anything- just having sound is good enough for me. So what should I do? I know I have 4 speakers in the car and that's about it.
any amp will work, use a mini-to-RCA cable -- connect sound card to amps RCA inputs
your concerns are:
1- remote turn on lead (from pc power supply to amp)
2- speaker wiring (easiest to wire to the car's original hardware)
this is enough to get you started...
EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot --
see pics and write up here!!
