The MP3car.com Store
Thread Tools Display Modes
Old 09-22-2006, 08:17 PM   #1
My Photos: (0)
How to power neon in sub box?
I am building a sealed sub box, with two 12 inch neon tubes on the inside. What is the best way to power these neon tubes? Thanks for any suggestions.
black06stang is offline   Reply With Quote
Sponsored Links
Old 09-22-2006, 08:21 PM   #2
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
i guess you could use another speaker wire cup to get power to the tubes. or just run wire into the box through a hole then silicone the hole up
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-22-2006, 08:35 PM   #3
My Photos: (0)
Where would I connect the power wires from the neon to?
Old 09-22-2006, 08:39 PM   #4
MySQL Error
scott_fx's Avatar
My Photos: (0)
the battery. better yet, add a relay that is switched on/off by the acc lead.
M10k
My Car Pc Install
Old 09-22-2006, 10:39 PM   #5
My Photos: (0)
There is no way to hook it up to speakers or the amp? I really do not want to mess with the ignition wires...
Old 09-22-2006, 11:39 PM   #6
Jahntassa's CarPC Specs
Jahntassa's Avatar
Vehicle: 2003 Pontiac Vibe GT
My Photos: (0)
You could do it if you have a relay. Wire the relay in-line with the remote-turn on lead from the radio, and power it off the battery line going into the amplifier.
The relay would then be able to connect to the amp's remote-turn on and power the neons, without damaging whatever is providing the turn-on voltage.
Jahntassa is offline   Reply With Quote
Old 09-23-2006, 12:24 AM   #7
MySQL Error
scott_fx's Avatar
My Photos: (0)
err...isn't that what i just said?
M10k
My Car Pc Install
Old 09-23-2006, 04:27 AM   #8
Jahntassa's Avatar
My Photos: (0)
Well, yeah, it was. I was just, y'know...expanding on it.
"scott_fx's advice, now in High Definition!"
Old 09-23-2006, 07:06 AM   #9
FC3S's Avatar
My Photos: (0)
no truly safe way, you could hook it up to your cigarette lighter if you wanted, but its not the safest way
and get LED's they run off 12v anyway, then you wont need an inverter/transformer box (whatever they run on)
FC3S is offline   Reply With Quote
Old 09-23-2006, 07:29 AM   #10
My Photos: (0)
No, you said acc lead, not remote turn-on wire
Shadow is offline   Reply With Quote
Sponsored Links
Old 09-23-2006, 12:18 PM   #11
MySQL Error
scott_fx's Avatar
My Photos: (0)
hahaha
hahaha...again
M10k
My Car Pc Install
Old 09-23-2006, 02:12 PM   #12
Vehicle: 1999 Saturn SL2
My Photos: (0)
don't hook the neons into the remote turn on line if its from your cd player as well as the amp, that will draw too much current, and the step up transformers in the neon sets will introduce interferance into the line its on more than likely. Make sure you use the relay like others stated.
Killa200 is offline   Reply With Quote
Old 09-23-2006, 03:20 PM   #13
FC3S's Avatar
My Photos: (0)
use LEDS and not neons, and u dont have transformer issues..
or current issues either, as LEDS use barely anything
Old 09-23-2006, 03:50 PM   #14
My Photos: (2)
depending on the kind of car you have, If its a sealed trunk wire into the light that comes on when you open the trunk, whats the point of having the neon on when nobody can see it..
And heres a link to a nice and small terminal cup that will work well in this application
http://www.partsexpress.com/pe/showd...number=260-301
Ces///M3 is offline   Reply With Quote
Old 09-23-2006, 04:33 PM   #15
Jahntassa's Avatar
My Photos: (0)
I had neons in one of my previous sub boxes hooked up the way I suggested, I never had any sort of 'interference' introduced anywhere because of it.
Sponsored Links
vB code is On
Trackbacks are Off
Travla AC/DC power supply cable Change Power Supplies 1 07-25-2006 10:04 PM
12v Power Supply at MP3Car.com store mykolJay Power Supplies 6 02-02-2006 09:17 PM
F/S: JL 12w7 Subwoofer with box!!! Pictures inside neema12 Classified Archive 10 08-29-2005 08:45 PM
Darn ITPS! Need power help! DJ-FrosT Power Supplies 1 07-16-2005 07:40 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
