The MP3car.com Store
Thread Tools Display Modes
Old 09-28-2006, 12:24 AM   #1
My Photos: (0)
much needed help on which amp i need
aight to make this short and simple, i know basically nothing about systems. i got these subs for free so im not gonna complain. i got 2 12'' powerbass subs (model- M-12D). Dual 4 ohm impedence. 700 watts recomended power. 350watt RMS recomended. my question is what is the best amp i could buy for around $300. should i buy a 2 channel or 4 channel. And how many watts should the amp be?
------ive been told a 4 channel amp and to bridge two channels together for each sub, and to connect the parallel to make 2ohms.
twistershorty2 is offline   Reply With Quote
Sponsored Links
Old 09-28-2006, 05:38 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
This forum is dedicated to CarPCs and installing them in your car.
The car audio forum is dedicated to integrating your car audio system with your CarPC.
For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
http://www.elitecaraudio.com
http://www.carsound.com
http://www.caraudioforum.com
http://forum.sounddomain.com
http://www.realcaraudio.com
http://www.carstereo.com
http://www.caraudiomag.com
http://www.termpro.com
http://www.the12volt.com
http://www.talkaudio.co.uk
http://www.caraudiosecurity.com
et. al.
There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
Good luck.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Sponsored Links
vB code is On
Trackbacks are Off
Engine Noise due to ground loop or amp? matt11601 Car Audio 29 05-07-2008 07:18 AM
Brand new AMP, Busted.. Biograph1001 Car Audio 7 02-19-2006 10:54 AM
Powering Carputer and amp ... TxMazda3 Newbie 7 06-03-2005 03:12 AM
Having problem with AMP, need HELP!! ryuandwings Car Audio 31 05-01-2004 07:31 PM
EPIA M9000 connection to car amp wi77iam General Hardware Discussion 2 08-08-2003 01:37 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
