Old 10-11-2006, 09:24 AM   #1
Epon's Avatar
Invert Phase by Reversing +/- Terminals?
Hey, I understand the concept of just simply reversing the terminal connections to invert the phase on my sub, but if I was wiring it as such:
I would still ultimatly just plug the + into my amps - and vice versa, right? Or do I need to reverse that wiring diagram as well? Thanks.
2004 Ford Mustang
Epon is offline   Reply With Quote
Old 10-11-2006, 09:52 AM   #2
dan__wright's Avatar
if you reversed it on the voice coil connections it would cancel it out, you would be using the - cable on all + terminals so it would be the same as wiring it up normally. just change it at the amp end.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Old 10-11-2006, 09:54 AM   #3
x2
Shadow is offline   Reply With Quote
Old 10-11-2006, 10:13 AM   #4
You do realize what reversing the phase will do to your sub right?
JonDubya is offline   Reply With Quote
Old 10-11-2006, 10:20 AM   #5
nothing ?
Type-R Mini
Old 10-11-2006, 10:24 AM   #6
Jahntassa's Avatar
Well..if the sub is designed to compress the air in a certain way (Ie, compress the air in a sealed box), then having the sub reverse phase could potentially nix part of its usefulness, because it won't be compressing the air correctly.
Jahntassa is offline   Reply With Quote
Old 10-11-2006, 10:25 AM   #7
but if you do everything properly then running reversed isnt going to cause any problems.
Type-R Mini
Old 10-11-2006, 10:52 AM   #8
It can still cause problems...It'll push air when it's supposed to be pulling and vice versa, so when there's a bass hit, it can sound hollow or off beat.
Old 10-11-2006, 10:55 AM   #9
Epon's Avatar
If the ***-end of the speaker is outside the box, then I have to invert the phase, which is exactly what I'm doing.
2004 Ford Mustang
Old 10-11-2006, 11:26 AM   #10
Why does everybody second guess the guy without asking what he's doing?
Old 10-11-2006, 11:39 AM   #11
Epon's Avatar
Thank you.
And thanks for the simple help above, I just couldn't get it past my mind that it'd be that easy to just swap the terminals with this setup. Needed some backup before I went shoving wires into things. Haha, I'll have pics on the setup probably later tonite, I spent the entire weekend on this beast.
2004 Ford Mustang
Old 10-11-2006, 01:10 PM   #12
Nobody was 2nd guessing...I just wanted to make sure he knew what happens when phase is switched.
Old 10-11-2006, 01:23 PM   #13
MySQL Error
scott_fx's Avatar
i think they are just trying to be helpfull. no fault in that.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Can anybody recommend a Reversing Camera? ALonDonThinG General Hardware Discussion 19 03-16-2006 04:41 AM
Reversing Camera Auto-on question? sansoo24 General Hardware Discussion 6 04-26-2005 01:21 AM
Reversing camera power source? Psychobiker General Hardware Discussion 15 04-21-2005 10:12 AM
