Old 10-20-2006, 10:26 PM   #1
dima237's Avatar
Faulty amp or wrong wiring?
Well, my whole system is ready to go as all part are now in. I was just about to start with wiring audio first and decided to test a new amp that I just got off ebay (MTX 404). I powered everyting (power to battery directly for testing, remote to ACC and stock speakers through harness). Front speakers sound just fine, but rear ones a just kind of a quite buzzing noise, I can hear that it's the audio, but it's just quite and buzzing. I thought maybe it's my wiring to the harness, but when I connect the rear speakers to front output, it's fine. So I'm concluding that it's the rear outputs of the amp.
Is that right? Is it possible to have 2 out of 4 channels be fried? If that's the case, that would really suck as I was excited to finish everything on the weekend.
dima237 is offline   Reply With Quote
Old 10-20-2006, 10:50 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
Yes it is possible for 2 of your channels to go. If you really want to finish it fast, then get some splitters so that you get 2 channels out of the amp to the 4 speakers. dont do that for long though. You need an amp.
Old 10-20-2006, 11:22 PM   #3
dima237's Avatar
Thanks for quick reply. This blows. As they say, whatever can go wrong, will.
Amp Shuts Off ElementXofXMusi Car Audio 29 07-18-2006 07:34 PM
ITX sp1300-> AMP wrong resistance?!? Power_nisse Car Audio 7 05-13-2006 03:23 PM
Wiring a 5.1 centre channel into front left / right amp lines Goines Car Audio 26 12-20-2005 06:23 PM
vw mk4 monson amp and another amp colorless Car Audio 33 10-03-2005 12:32 PM
Wiring, fuse, amp, relay questions Vee24 General Hardware Discussion 7 05-25-2005 07:03 PM
