The MP3car.com Store
Thread Tools Display Modes
Old 10-22-2006, 03:42 PM   #1
XC-C30's CarPC Specs
XC-C30's Avatar
Vehicle: 1992 citroën AX MKII
My Photos: (0)
recomendations on sc with 5/6 outputs
Hi,
in order to use the thuneau frequency allocator for my 2.1 active sound-system (so it is actually 4.1), I need a soundcard with 5 or 6 outputs. I know there are PCI cards who have that many, but I rather use a USB-card because of the possible HDD-interference with PCI.
anybody who knows of such a card? thanks
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Sponsored Links
Old 10-22-2006, 03:48 PM   #2
XC-C30's Avatar
My Photos: (0)
ok, damn, really have to do some more reading.... I was looking for a card with 6 rca-outs, but thanks to my bro (really, thank you Joachim/JC!) I now know, I could also use one with 3 3.5stereo outs..... how stupid could I be
edit: one more thing, I really would like it to use 24bit in order to play dvd
edit2: needs to be ASIO-compatible
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 10-23-2006, 07:38 AM   #3
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
have you seen the stickey at the top of this forum that includes a bunch of USB/fire wire cards?
btw - not just 1/8" but you can also use 1/4" TRS jacks and just make custom RCAs. I'd go that route before 1/8" for sure.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 10-23-2006, 08:41 AM   #4
XC-C30's Avatar
My Photos: (0)
yes red, i've seen the sticky. problem is, most of the cards are only 16bit, but the few that are 24bit don't support ASIO....
yesterday I thought I found the perfect card for my needs (ESI gigaport AG), but that one also is 16bit.... Then I looked at an audigy2 NX, but that one seems to have trouble with the ASIO drivers and it seems to make the frequency allocater crash... (so I've read that at the thuneau forum)
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 10-23-2006, 08:54 AM   #5
_
My Photos: (73)
http://www.m-audio.com/products/en_u...e410-main.html
http://www.m-audio.com/products/en_u...hile-main.html
Not USB, but an option if you have room.
http://www.m-audio.com/products/en_u...10LT-main.html
Jan Bennett
Old 10-23-2006, 09:40 AM   #6
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
You might have to go the PCI or Firewire route instead of USB. I am not sure, but I don't know if USB bandwidth can do 8 channels using ASIO. There is not much buffering going on when you use ASIO instead of the regular microsoft direct sound or wavemapper from my understanding.
Red-
I'll add those to the USB/firewire soundcard list.
durwood is offline   Reply With Quote
Old 10-23-2006, 09:54 AM   #7
XC-C30's Avatar
My Photos: (0)
will be firewire than, cause I'm a little sceptical about PCI (HDD noise, cd-rom noises, mouse clicks).
Or I could just get a 16bit card, would it really be that bad with dvd?
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 10-23-2006, 10:13 AM   #8
Car Audio Moderator
durwood's Avatar
My Photos: (0)
I think you should be ok. bit depth is basically associated with dynamic range. 24 bits allow you to have a dynamic range greater than 100dB while the best you can with 16 bits is around 96dB. What does this mean? It gives you a more accurate sound, more detail, less artificial. Here is a good explanation.
http://www.pcrecording.com/dither.htm
I used a PCI soundcard folded over the top of my M10K using a PCI rsier card and as long as I didn't run any IDE cable too close to the soundcard I didn't have any noise issues on my analog outputs.
Old 10-23-2006, 12:31 PM   #9
XC-C30's Avatar
My Photos: (0)
ok, thanks durwood. gonna go with the ESI gagaport than, I think. I'll be watching DVD ony occasionally, so as long as music-cd's sound as thet should, it's all that matters.... and since cd's are recorded at 16bit....
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 10-23-2006, 01:23 PM   #10
XC-C30's Avatar
My Photos: (0)
most important is music-quality, because I recently joined a team that's competing in EMMA, just since a week or two. and I'll be joining them in competing next season (for SQ that is, SPL, not so much my cup of tea)
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Sponsored Links
Old 10-23-2006, 01:26 PM   #11
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Cool. SQ is where its at.
Oh and the ESI is a 24bit card.
Old 10-23-2006, 01:37 PM   #12
XC-C30's Avatar
My Photos: (0)
damn, really wasn't quiet awake when i read the specs
thanks for the notice durwood ok, that's solved than I guess?
so it's ASIA-supperted, 24bit and has 8 analog line-autos, am I correct? (just verrifying, 'cause maybe I overlooked somethin (again)
edit: why do I keep typing ASIA instead of ASIO?
edit2: analog outs instead of analoq autos (damn..... and I don't even ever touch alcohol)
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 10-23-2006, 01:43 PM   #13
Car Audio Moderator
durwood's Avatar
My Photos: (0)
hahaha. Let me know how that turns out for you. I am interested in going that route too...if it works. I bet a few other would be interested too.
Maybe you have been having to many of these
Just kidding.
Happy Tuning
Old 10-23-2006, 01:51 PM   #14
XC-C30's Avatar
My Photos: (0)
not gonna be using full potential of the frequency allocator at the moment though. It requiers a P4 2.0 to ise full potential, and I'm only running an AMD duron800 at the moment (well, not running anything at the moment actually, but gonna be soon)
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 10-23-2006, 01:53 PM   #15
_
My Photos: (73)
what are you doing about eq, time alignment, and phasing?
Jan Bennett
Sponsored Links
vB code is On
Trackbacks are Off
In-car PC controlling 12v outputs hardware/software ?!? skinhead General MP3Car Discussion 3 07-18-2006 12:26 PM
PCI Audio card with balanced outputs ? Maximus Car Audio 0 02-08-2005 08:31 AM
Is it possible to map different sound sources to front & rear outputs? Dominik Software & Software Development 8 09-27-2004 10:20 AM
os and input recomendations 4 low spec pc Bodgy Newbie 6 11-24-2003 11:27 PM
Amp recomendations stevens General Hardware Discussion 12 06-06-2002 04:29 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
