Old 10-25-2006, 04:45 PM   #1
korek28's Avatar
korek28 is an unknown quantity at this point
2-Channel Amp---4 Speakers
Ok here is my situation:
I was thinking of getting a set each of Polk db650 and Polk db675 speakers ( both 6-60 W RMS ) for my car once I finish up my Car PC project soon.
Now since I want to completely remove the head-unit from the car and run the sound directly from my PC to the speakers, I will be getting a Rockford Fosgate P3002 ( 2-channel amp, 75 W RMS x 2 ) to power the speakers.
My question is:
Since the amp is 2-channels and I will be running 4 speakers from it, does that mean once I split each channel to power 2 speakers each ( 2 channels x 2 speakers per channel = 4 speakers ), that each speakers will only get half the power ? Will each speaker get only half of the 75 W RMS ?
Thanks for any help on this.
korek28 is offline   Reply With Quote
Old 10-25-2006, 05:19 PM   #2
XC-C30's Avatar
XC-C30 is on a distinguished road
you'll have to wire up front and rear of each side, that way you'll play at 2 ohm. BUT, in that case the dampingfactor of your amp will draw back, and soundquality will be drawn back also. so what's the power output of your amp at 2 Ohm? it should be around 120watts RMS per channel, for you to get full advantage of the speakers.
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 10-25-2006, 05:37 PM   #3
korek28's Avatar
It's about 150 rms X 2 @ 2 ohms ...
thanks for the help i got a better understanding of it now
Old 10-25-2006, 06:03 PM   #4
XC-C30's Avatar
wire the front and rear speakers together, and you should be alright. but be sure to set your gains right, cause you're overpowering your speakers, which could lead to blowing them in the end, if you're not carefull
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 10-26-2006, 02:51 AM   #5
korek28's Avatar
Ok here is what I've figured out so far with some help from some people from school. Seem right to you guys ?
Specs of AMP
- 75 W RMS x 2 @ 4 ohms
- 150 W RMS x 2 @ 2
Specs of Speakers
- 6-65 W RMS; 180 W Max
- impedence: 4 ohms
So if the above speakers are hooked up in parallel to one channel,
it would be 4 ohms in parellel with 4 ohms, making it 2 ohms.
( 4 || 4 = 2 )
Thus each channel would run @ 2 ohms, 150 W RMS per channel.
And thus since there is 2 speakers on 1 channel, 75 W RMS would go to each speaker.
Now is this correct ? Or am i making some mistakes here.
Old 10-26-2006, 02:59 AM   #6
Sidewalksalvage's Avatar
Sidewalksalvage is on a distinguished road
The amp is stable at 2ohms? Thats something important to check.
I believe if in series you would get half power to each speaker right?
But parallel will give equal power to each.
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Old 10-26-2006, 03:05 AM   #7
korek28's Avatar
According to crutchfield.com it says that it is stable at 2 ohms....
not entirely sure on the parellel / serires part as to which one would give you half the power to each speaker... that is why i was asking.
how would i hook it up to get half power of each channel to each speaker?
Old 10-26-2006, 03:45 AM   #8
DJiK's Avatar
DJiK will become famous soon enough
Parallel & Series diagrams and resistance calculators --> http://www.the12volt.com/caraudio/boxcalcs.asp
It's true that a light bulb will be twice as dim when wired in series (vs. parallel), but I can't say the same about speakers.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 10-28-2006, 10:56 PM   #9
monkeyc is an unknown quantity at this point
You wouldn't buy a minivan to go off-road'in, would you?
The answer is: If you series the speakers, then you run each channel of the amp at 8ohms and you get half the effective power to each speaker but a cleaner sound since the THD (Total Harmonic Distortion) is decreased by ~half.
If you parallel them like you have indicated in the diagram above, then you will get twice the power out of the amp, but about twice the THD than if you just amped two speakers (one on each channel). This is a typical setup but I never recommend it since there will be a somewhat noticable difference in the sound because they are full range speakers. A two channel amp is capable of running more than just two speakers, but it is not designed to do so exlusively. So my question is WHY? Why are you going to have a two channel amp run four channels? That is what they design 4 channel amps for. You will lose your fader ability (which is a big factor in adjusting your staging) and you will gain unwanted noise.
I would do one of three things if it were me.
1. Return/sell the two channel amp and buy a four channel.
2. Forget about the rear speakers altogether and just amp the fronts. You want your staging to be coming from the front as if you were at a concert or at home infront of a TV. Rear speakers are just for rear fill and are almost unneccessary unless you have a 4.1 surround card or better.
3. Buy an additional 2 channel amp for the rears.
monkeyc is offline   Reply With Quote
Old 10-31-2006, 01:01 AM   #10
korek28's Avatar
monkeyc,
Yea I actually was thinking recently that it would be better to go with 4-channel amp over the 2-channel amp as it would make things alot simpler for me.
Now here's my new question: Already having a 2-channel amp, is it beneficial to sell this one and purchase a 4-channel amp, or is there no real difference if i run two 2-channel amps, one for the fronts and one for the rears??
Old 10-31-2006, 01:18 AM   #11
Depends on power... sometimes you can get more power with two 2ch amps.
I suggest maybe getting a slightly more powerful amp for the front speakers so that you have crisp sound in the front and good fill from the rear
Overall there is no difference between a 4ch and a dual 2ch system when properly set up.
Current Progress:
Brown 2010
Old 10-31-2006, 07:49 AM   #12
Shadow is on a distinguished road
Why not unplug the rear speakers?
Shadow is offline   Reply With Quote
Old 10-31-2006, 08:08 AM   #13
Cuz thats just depressing....
But if you have an HU, you could run the front off the amp and the rear off the HU...
Current Progress:
Brown 2010
Old 10-31-2006, 10:02 AM   #14
LaxPlaya8513 is on a distinguished road
but rear fill = annoying. Your diagram above is correct, wiring 2 4ohm drivers in parallel will lower the resistance in half to 2ohms per channel. As long as your amp is capable of running 2ohm leads per side you'll be fine. Alot of 2ch amps now a days are stable to 2 ohms. The only downside from this setup is the fact you lose the fading capabilities which many people really don't care for all that much anyhow.
LaxPlaya8513 is offline   Reply With Quote
Old 10-31-2006, 01:09 PM   #15
BenOBS's Avatar
BenOBS is an unknown quantity at this point
Dont forget the sound quality downside...
Get a second 2 channel or get a 4 channels... Your carpc will allow you to setup the rear fill right...
BenOBS is offline   Reply With Quote
On a 2 channel amp that I plan on bridging, do I need BOTH rca ins? FyreDaug Car Audio 67 10-15-2006 09:35 PM
Sound card to speakers without HU or Amp. spoonraker General Hardware Discussion 12 10-15-2006 08:00 AM
Wiring a 5.1 centre channel into front left / right amp lines Goines Car Audio 26 12-20-2005 07:23 PM
Bazooka 4 channel Amp tiggs Classified Archive 5 06-03-2005 11:52 PM
6 channel amp? auto_robotics Car Audio 4 11-24-2004 02:33 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
