Ok, I bet this reply will be too late, but here it goes anyway. Im a MECP certified installer. Ive been installing professionaly for about 3yrs now. I also have college background in Physics and Electronics. Enough about me, I just wanted to give some peace of mind about my reply.
The MTX 5500 DVC Sub in this case is a dual 4ohm speaker. This simply means that there are two seperate voice coils (copper windings in the motor assymbly) that are both rated at 4 ohms of resistance each. If you wire the two voice coils in parallel as mentioned above the resistance will be divided by two.
Parallel: 1/(R total) = 1/(R1) + 1/(R2) +.......... +1/(Rn)
You will want to wire your single DVC sub up this way in order to get twice the effective power out of the amp. Since the amp is a mono block (meaning it only has one output channel), it will be able to handle ohm loads lower than 4. But, like everything else, there is some compromising. By lowering the resistance by a factor of 2, you increase the THD (Total Harmonic Distortion) by a factor of ~2. In other words, the sound quality coming from this set up is lower than a similar system with a 4, 8, or 16 ohm load (typical values for car and home use). That being said, you are probably not interested in sound quality since you have puchased products that arent really designed for sound quality, but rather SPL (Sound Pressure Level).
So, in conclusion, wire both positive terminals from the sub to the positive terminal of the amp, and both negative terminals from the sub to the negative terminal of the amp and you'll have beats!
P.S. Don't ever underestimate the power of a well designed/built speaker enclosure! Get a good ported/vented box that closely matches the volume requirements of the sub for SPL!
Good luck!
