Old 11-01-2006, 01:18 PM   #1
Crazystick is on a distinguished road
Alpine digital audio setup. . maybe.
Hey guys,
Wanted to get your thoughts on a digital audio setup I had in mind.I want to keep a headunit, just in case the car pc goes down.
I wanted to go with an alpine Headunit, DSP, CPU (undecided), and lilliput manual "push" screen.
Here is my main layout.
Alpine DVA-9860 - ---->DVD/CD/MP3/WMA Receiver
OR .. OR
Alpine CDA-9856 -- -- ->CD/MP3/WMA Receiver
Alpine PXA-H701 Multimedia Manager
CAR PC - with digital audio, soundcard.. Setup at a later time
Lilliput 7" manual push
I dont necessarily have to with a head unit labeled DTS / Digital Audio right?
The processor handles that, correct. Because if thats the case. I can probably go a little cheaper and go with the Alpine CDA-9856
The only real difference between the two models , I think is the dvd playing ability, and I got confused on the DTS part, Does that mean it is sending out the DTS signal to the processor? and thats about it.
Only concern is that I am not sure if I need a side head unit for the DSP itself.
Here is a layout of what Im thinking of doing..
Crazystick is offline   Reply With Quote
Old 11-01-2006, 03:18 PM   #2
forgot to mention the Alpine DVA-9860 - ---->DVD/CD/MP3/WMA Receiver has an optical output and would connect that optically to the DSP,
But the Alpine CDA-9856 -- -- ->CD/MP3/WMA Receiver Does not, So I am not sure how to connect audio from the 9856 to the DSP if I wanted to go that way.
The only reason I am posting all this is to make sure this is more or less guaranteed setup for a carpc can just come and hook up.
Old 11-01-2006, 10:44 PM   #3
pancit175 is on a distinguished road
Only some models may be completly compatible with the PXA-H701. You should probably look into that a little be more to for sure. What it might come down to is that you may need to get the controller RUX-C701 to configure it if the deck is not compatible. But you pretty much have the general setup I have except for the controller instead of the deck.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 11-01-2006, 11:01 PM   #4
XC-C30's Avatar
XC-C30 is on a distinguished road
why would you wanna go with a HU that plays dvd? I know, I know.... in case the carpc fails.... But how many chances are there it's going to? In my opinion, I wouldn't spend the money on it. The chances the HU fails on you is the same, so what are you gonna do than? buy a 3rd HU incase both carpc and HU fail on you?
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 11-02-2006, 06:26 PM   #5
3onDubs's Avatar
3onDubs is on a distinguished road
Why not get a head unit that can do everything a carpc can and is designed to be in a car....like, say, the Alpine W200 that is fully compatible with the H701? You'll only be missing internet, but you can check your email when you get home.....
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 11-02-2006, 06:37 PM   #6
XC-C30's Avatar
cost?
I bet a carpc will be cheaper, and most important: you can completely design/build it according your needs/likings
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 11-04-2006, 09:47 PM   #7
Saca_Saca is an unknown quantity at this point
Hello,
This is very close to the same set-up I'm about to have installed.
I thought you needed the RUX-C701 controller for the 701 to use in alone mode which would enable you to pick the optical input of your choice.
I am not sure if you can choose optical inputs without it?
Saca_Saca is offline   Reply With Quote
Old 11-06-2006, 12:58 PM   #8
Alpine ....tech support
apparently You are correct. Which is not what I wanted to hear. The PXA-H701(digital processor) does require the controller RUX-C701 to control it. I just got off the phone with alpine tech rep. The only good thing is that the controller is the size of 1 DIN faceplate. It has no depth to it and could easily be mounted elsewhere. But Unfortunately fo this setup it seems that cost is not worth it.I will look into a different digital processor and possibly different setup.
Old 11-06-2006, 07:46 PM   #9
Yeah I went with the RUX-C701 and made a lil pod that mounted to the headliner of my car. It's under an inch thick.
I got those 2 pieces for just under $600 after shipping. I think you can probably swing something like that off of ebay, or froggle.
PROGRESS:
Old 11-25-2006, 10:45 PM   #10
crabbdaddy is on a distinguished road
RUX-C701 install pics?
any pics of your RUX-C701 install? thinking of doing the same when my RUX-C701 arrives. im finding info on the unit but no install pics for ideas.
thx.
96 cobra
suspension: MM CC plates, H&R super sport, bilsteins, steeda:bump steer kit, X2's, moly SFC's, triax shifter. MGW handle, cobra knob. Audio:RUX-C701, PXA-H701, MRV-F545, MRD-M1005, SIR-SC-H1, DMHD1000, Polk/Momo MMC6500, MM2104
crabbdaddy is offline   Reply With Quote
Old 11-26-2006, 10:07 AM   #11
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Go to:
http://www.mj-garage.com/cpg/thumbnails.php?album=15
I've got install pictures there of the controller.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
SDPIF digital Coax into car audio pieces RedGTiVR6 Car Audio 34 10-14-2008 01:06 AM
Digital Audio Processors? 97GST Off Topic 3 03-20-2006 01:20 PM
Fight for Digital Rights - Broadcast Flag For Audio in USA Fiberoptic Off Topic 7 03-12-2006 10:19 PM
1992 Subaru SVX ITX, Xenarc TS, DVD-ROM, Digital Audio Processor rmjjensen Show off your project 18 07-27-2005 03:01 PM
adding DTS Dolby to my audio setup lawrence Car Audio 12 11-05-2004 04:01 PM
