Old 11-02-2006, 05:14 PM   #1
SexualChocolate is on a distinguished road
rear speakers pop when I brake (non carputer related, I think)
So I have my install pretty much done, but many times (95% of the time) when I get on my brakes, my rear speakers will pop. Its only coming from my rear speakers, only when I brake, but it happens w/ the radio/computer/CDs.
Im using 2 2-channel amps, so Im thinking that it would be a problem with the amp powering the rear speakers, does that sound right?
I know a ground loop can cause the alternater whine, but can a ground loop cause this popping? I did test the amp with a multimeter and got 12V, so I wouldnt think thats the problem.
Any ideas on whats causing this?
SexualChocolate is offline   Reply With Quote
Old 11-02-2006, 06:06 PM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Swap your speakers wires...switch your front speakers to the rear amp and then rear speakers to the front amp. See if the problem stay with the one amp or it follows the speakers.
If it does it on the fronts then it is a problem with that one amp. If it follows the speakers maybe one of your speaker wires is pinched and touching ground somewhere.
Just start doing process of elimination in this case.
Makes sure your amps are grounded well. (no paint) Make sure your computer is grounded well.
System always under construction
durwood is offline   Reply With Quote
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 06:37 PM
FS:Some carputer related, some not... riddle14 Classified Archive 21 10-26-2004 04:06 PM
FS:Lots of stuff,some carputer related some not riddle14 Classified Archive 37 09-11-2004 02:12 AM
Pop Sci Carputer anti General MP3Car Discussion 13 08-26-2004 10:11 AM
Requesting advice on anything Carputer related... Raekwon General Hardware Discussion 21 04-05-2003 12:23 PM
