Old 11-04-2006, 05:41 PM   #1
cheever's Avatar
cheever is on a distinguished road
rca wire too long?
Here's what I got hooked up at the moment:
A 4channel amp powering the regular car speakers and a 2ch amp powering my subs. I have an RCA cable running from my center console to my 4ch (I split th signal just before the 4ch amp to feed my sub amp). My RCA cable is ~20 ft long and all I have pushing music is my IPOD via a 1/8" to RCA convertor. What Im running into is that after a while the front deck will totally go out, until I turn up the volume real fast, then everything kicks back in for a little while longer. This problem goes way once I plug up power with a cigarette lighter adapter. That's fine but apparently it's not grounded well enough because I can hear the noise that matches the engine rpm. I hooked up the ipod to the 4 ch amp directly with a really short RCA, everything sounded great. Is there any chance there is a signal booster for an RCA cable that isn't a full blown amp? It seems to me that the ipod does not push enough power through it's headphone jack to give me what I need.
Perhaps there is a better method than what I have...cheaply..
Once again I truly appreciate anyone who takes the time to help me out on this.
cheever is offline   Reply With Quote
Old 11-04-2006, 06:41 PM   #2
Shadow is on a distinguished road
What you're describing is a line driver. A good one's going to run about $65.
Shadow is offline   Reply With Quote
Old 11-04-2006, 07:03 PM   #3
monkeyc is an unknown quantity at this point
Yup, what Shadow said!
monkeyc is offline   Reply With Quote
Old 11-04-2006, 07:52 PM   #4
technostar's Avatar
technostar is an unknown quantity at this point
i got one of these CLARION EQS746 Equalizer. it has two inputs, aux and main, and you may select each one by pressing a button.
broom-broom-pc
m-atx:amd2600xp:512mb:40gb:m2-atx:roadrunner:lsxvoid
technostar is offline   Reply With Quote
Old 11-04-2006, 11:41 PM   #5
XC-C30's Avatar
XC-C30 is on a distinguished road
and what the hell does this have to do with the problem discribed by the topic starter?
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 11-04-2006, 11:55 PM   #6
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
i think you could use a preamp as well. You can build one like the picture for like $5 and it will be fine for the audio that the iPod spits out. If you need audiophile type music, then you need to spend some money like shadow said.
Just replace the "mic in" with "ipod in"
Old 11-05-2006, 03:32 AM   #7
technostar's Avatar
he's asking for a signal booster for rca. this preamp i was referring to may serve as well like a line driver. was i out of topic here?
broom-broom-pc
Old 11-05-2006, 04:03 AM   #8
XC-C30's Avatar
meh, why buy an EQ if you just need a line-convertor? if you wanna use an EQ, you'll have to spend money for a good one, and since he's just looking for a line-convertor, that seems a little over the top in my opinion.
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 11-05-2006, 06:21 PM   #9
Hey all you rockheads, a preamp IS a line driver.
Old 11-05-2006, 06:30 PM   #10
2k1Toaster's Avatar
I never use word like that because I know what I want it to do, so I don't know what it is called. I call pre-amps/linedrivers: boosters. I know, makes no sense, but I know what I want.
Old 11-05-2006, 08:01 PM   #11
cheever's Avatar
well...turns out I forgot I have a line output converter with gains on it already in the car...so Ill probably splice a headphone jack into the converter and see how that goes. I really appreciate everybody's help. If that doesn't work Im going to try 2k1toaster's idea
Old 11-05-2006, 11:16 PM   #12
How will this help on an audio input?
Old 11-07-2006, 09:23 PM   #13
cheever's Avatar
With a line output converter I can split the headphone jack into the converter, which has identical outputs, which have gain control, so perhaps if I turn up the gain? worth a shot anyway, I already have it, and it only cost me 14 bucks
Old 11-08-2006, 01:07 PM   #14
That thing is totally passive and cannot turn the voltage up, just down. To add voltage you need an amplifier which needs power.
Old 11-09-2006, 04:39 PM   #15
cheever's Avatar
Yeah, you're right. It looks like Ill be hunting down parts for that circuit I see in that earlier post. Thanks again.
extending my TS's ac adapter wire skadoo323 Power Supplies 2 02-02-2006 01:09 PM
Long RCA or Line-Out? jimothy General Hardware Discussion 2 04-29-2005 02:39 PM
Opus 90W power supply wire, 8 ga wire? muldrick Power Supplies 12 08-27-2004 11:27 PM
Looking forward to get the DC-DC PSU and now... cwho122 Newbie 11 03-09-2004 10:59 AM
RCA to Speaker wire? greenglo General Hardware Discussion 3 02-16-2004 03:20 PM
