11-05-2006, 12:28 PM
#1
1.2 Farad Capacitor.. Need Help!
I recently bought a single 10" Power Acoustik sub with 1800 watt max. I am feeding 980 watts to it with a Power Acoustik amp. I also have 4 guage wire. Everytime my sub hits a hard note my lights and other electrical components in my car go dim. So I read up on some capacitors and I ended up buying a 1.2 Farad Voodoo Rack Mount Capacitor. I wired it up and yet my lights still go dim. I am not sure if it is even working.. I charged the cap and everything and I'm almost positive it is wirred correctly. I need to know what else there is I need to do or what I missed.
11-05-2006, 01:29 PM
#2
1. Max wattage is a useless #. Look at RMS.
2. You should have read about how caps are not a cure for dimming lights. You need to upgrade the Big 3. Do a search for "Big 3" on this or any car audio forum. Or even
11-05-2006, 02:15 PM
#3
Thanks.. I didn't even know about the "big 3". I will go out and buy some larger wire and try it out. Thanks for the idea.
Any more advice?
11-05-2006, 06:20 PM
#4
Don't use a cap!
11-05-2006, 06:23 PM
#5
_
and do the big 3, all the advice you need right now.
11-05-2006, 06:40 PM
#6
Is it bad to use a cap? What are the Pro's and Con's?
11-05-2006, 06:41 PM
#7
_
this has been covered in great detail on this forum, many many times.
11-05-2006, 06:42 PM
#8
IS it bad to use a cap NO but pointless!.....I think that a cap really doenst do much unless you get like a 10 15 farad cap
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
11-05-2006, 09:30 PM
#9
It can be bad when your adding another electrical component to an already overdrawn electrical system. Like red said its been discussed countless numbers of times on many forums.
11-05-2006, 11:15 PM
#10
It's still stupid. A 10 or 15 farad cap would cost easily two times what a good solid battery would cost with a fraction of the performance.
PS 1000th post
11-05-2006, 11:21 PM
#11
Car Audio Moderator
I hope you are talking about the main car battery...and not adding a second battery. A second battery will only cause further problems.
It's a Power acoustik amp...it won;t draw that much power. Just use good quality wire and make sure its grounded well and all should be fine.
System always under construction
11-05-2006, 11:31 PM
#12
i hate to say it but... YAWN.
11-06-2006, 06:26 AM
#13
Yea. Today when I get back from work i am upgrading a couple of my wires. I'll see where that takes me. Lucky I didn't tear apart my cap box and still have the recipt so if its not needed. I'll get my money back.
And yes I am running a stock battery. No worries though. Soon to be upgraded with a Yellow Top one. Those are around $125-$150 right?
11-06-2006, 07:30 AM
#14
Yellowtop are best for if you run your system with the car off for long periods of time. If you don't I would get a redtop (or equiv).
11-06-2006, 07:49 AM
#15
_
yellow tops are around 200, red tops around 150.
If you use the car every day or at least every other day, go with a red top, else stick with a yellow top if the car sits for more than 2 days without being driven.
| Thread Tools |
| Display Modes |
Linear Mode
