Old 11-05-2006, 06:09 PM   #1
MuDvAyNeDude122 is on a distinguished road
speaker wiring question
i just set up my carpc and im trying to get all the speakers set up. i have 2 front speakers and a sub. My amp is a us amp 4300x which has 4 channels. i bridged the rear 2 channels for the sub and im using the front 2 channels for the front 2 speakers. on my sound card(soundblaster live 5.1) i plugged in the front 2 speakers in the line out jack and the sub into the analog/digital out jack. it doesnt really sound right though. seems like i hear more bass from the front speakers than the sub. do i have this wired right? or do i have to mess with the settings on my software? thanks btw i am very new to anything car audio related and this is the first time i have ever messed with this kind of stuff. thanks
MuDvAyNeDude122 is offline   Reply With Quote
Old 11-05-2006, 06:20 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
chances are the sound card isn't putting a signal out of the analog and digital outputs at the same time
does your amp have a 2/4 channel switch to allow the rear inputs to feed off of the fronts signal? If so, unplug the rear rcas and flip the switch and see if you notice a difference.
Have you adjusted crossovers for this amp at all? Have you gone into the settings on the sound card to tell it what outputs to use?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 11-05-2006, 06:24 PM   #3
the sub is doing something, but not much. there is a 2/4 channel switch on the amp, i have it set to 4, then another switch i have set to front high/rear low, i wetn into the settings for the sound card but i did not see any settings to tell it what outputs to use.
Old 11-05-2006, 06:31 PM   #4
_
Is this the card that you are using?
http://www.soundblaster.com/products...ct=10702&nav=1
You're not going to be getting an equal signal out of both outputs on that card. Usually these cards are not designed to put a signal out of the analog and the digital ports at the same time. Not to mention, how are you turning that digital tos-link signal into an analog signal?
Jan Bennett
Old 11-05-2006, 06:51 PM   #5
no my card isnt an external card. and like i said theres a line out port and a analog/digital line out port so i think you can plug in either. i just went by the instructions for the sound card, it said i can plug speakers into the line out and the analog/digital line out can be used for a center speaker or subwoofer. but if this isnt the right way, what do you suggest i do?
Old 11-06-2006, 03:45 PM   #6
cmon my car nees your help
Old 11-06-2006, 07:52 PM   #7
LaxPlaya8513 is on a distinguished road
is your amp wired for low pass on the rear channel lead? That's the easiest fix. Possibly the amp sees that it's trying to cross over highlevel only and the input you're giving it is only low freq.
LaxPlaya8513 is offline   Reply With Quote
Old 11-06-2006, 07:54 PM   #8
oh, btw, that's the sound card i'm using right now on my PC
M2-ATX Wiring question ratboy Power Supplies 5 04-14-2007 07:11 PM
Speaker quality question Strange Car Audio 3 08-14-2006 02:34 PM
amp input wiring question rlee02135 Car Audio 10 07-27-2006 01:58 PM
Need Help - BMW's Signal Differential Speaker Wiring, Amps and SVEN4 lloydy Car Audio 8 02-14-2006 07:43 PM
Headless Setup - Quick Amp Wiring Question. crosseye Car Audio 6 07-13-2004 03:18 PM
