You can not run a 2ch amp at 2ohm, because it will run each channel at 1ohm, and your amp is not able to run that load. You will need a mono amp to put them at 2ohm
The only way to run a pair of those subs is to do all connections in series at 8ohm. This will most likely not give you the sound you want.
