Quote: Originally Posted by
sheepy
Ok, so should the relay be wire straight to the battery or would that be to much power to the amp???
Welcome.
You should read the FAQ section. Your question indicates that you are unfamiliar with how wiring works. Also, you should not need a relay for an amp. Something just isn't righty.
Please read the manual that came with your amp (and if you think saying "I bought it used, it didn't come with an manual" then you should serarch the web for a maual) and look at
www.the12volt.com and do some internet searches on how to install an audio amp.
Michael
