Old 11-14-2006, 02:54 AM   #1
Abmolech is on a distinguished road
Talking Suitable hardware
Hi,
Taken the plunge and have ordered RME HDSP 9652 sound card and two AEB8-0 extension cards
http://www.rme-audio.com/english/hdsp/hdsp9652.htm
The system only requires one PCI slot and enough redundant space to stack two "sound cards" on top.
This system should give me 16 analogue outputs. I wish to do a surround system with each driver on its own channel.
I have suitable drivers and amplifiers for this task.
Fronts are an MTM array wit two 3" and one tweeter in the kicks and an ambient tweeter in the pillars. Mid bass duties are 8" woofers in the doors.
Centre channel is an array of six 3'' and two tweeters
Rears are stereo 3" and 8"
Subs are four 8" and two 12 NLC's.
The amplifiers are six DLS A3 with three A2 for the tweeters.
The program for the crossovers is from here.
http://www.thuneau.com/allocator.htm
I can run multiple programs as long as the cards are synchronised, and running on a single instance of AS-IO.
What I require is a suitable windows based PC, case and power supply.
I will be building from scratch.
Please recommend,
Case,
Power supply,
Motherboard,
CPU and ram.
Thanks in advance
abmolech.
Abmolech is offline   Reply With Quote
Advertisement Sponsored links
Old 11-14-2006, 06:43 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
I recommend doing some research, starting here: http://www.mp3car.com/vbulletin/newbie/78795-new-carpcs-dont-know-where-start.html
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 11-14-2006, 06:58 AM   #3
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
Quote: Originally Posted by Abmolech View Post
Hi,
Please recommend,
Case,
Power supply,
Motherboard,
CPU and ram.
Thanks in advance
abmolech.
There will be *A LOT* of real-time processing going on while playing music, so I would recommend you check out the specs needed for hard and software first.
I guess you'll need a fast processor and a beefy power supply to go with that.
Good luck!
JC-S60 is offline   Reply With Quote
Old 11-14-2006, 08:50 AM   #4
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Wow. Good luck. Join us over here...
http://www.mp3car.com/vbulletin/show...ht=bit+perfect
and here...
http://www.diyaudio.com/forums/showt...threadid=63078
After reading those threads you will see you will need some pretty heavy computing power.
System always under construction
durwood is offline   Reply With Quote
Old 11-14-2006, 09:15 PM   #5
Agreed.
Any particular favourites?
Leaning towards Intel Core 2 Duo E6700, 2.67GHz, LGA775.
And a laptop type harddrive.
Old 11-14-2006, 09:21 PM   #6
Car Audio Moderator
durwood's Avatar
I prefer AMD. I switched to P4 a while back because of the HT but my AMD 1500XP could take on this 2.6 P4 anyday. Just remember to account for heat and power consumption is all I can recommend. I think most of the demanding audio processing programs require somthing over a 1.5Ghz.
Old 11-14-2006, 09:34 PM   #7
Supposedly these chips run at 2.2 volts, and require less wattage than their competitors.
For heat, any advantage in using water cooling?
Power I have a 250 amp alternator and a digital regulator and dual car batteries.
http://www.sterling-power.com/htm/ab1290.htm
If you mean power supply, The only ones I have seen are the opus 250 watts.
I will only be running an on board video card with the lowest I can find. This box is only a pro logic II decoder with crossover/ equaliser/DRC and weighted volume control unit.
Old 11-15-2006, 10:22 AM   #8
Car Audio Moderator
durwood's Avatar
Excellent. That will probably help. I have seen AMD coming out with reduced wattage processors as well. Just make sure the operating temperature of the processor is can withstand the temperature extremes that happen in a car.
As far as water cooling, I personally wouldn't want water anywere near my electronics. There are some threads on this forum discussing different cooling options. You can run into problems if you keep it too cool on a hot day. When the car warms back up, you could run the risk of condensation.
Old 11-15-2006, 10:49 AM   #9
Thanks I will check that.
I am looking at the mobile range of CPU as well, apart from twice the price, is power consumption critical to success as a car pc?
Old 11-15-2006, 12:28 PM   #10
Jahntassa's Avatar
Jahntassa is on a distinguished road
I would not try water cooling in a car environment. Way too many shakes and jiggles to mess with things. I have water cooling on my desktop and I get paranoid that something is going to come loose whenever I move the machine, which, isn't that often.
Jahntassa is offline   Reply With Quote
Old 11-15-2006, 01:14 PM   #11
Car Audio Moderator
durwood's Avatar
I just depends on how you want to power it. I would try to stay away from power invertors at all costs. It will save you many headaches. As of right now the largest DC-DC power supply is a 250W, however I have a feeling that there will be other options down the road. If they made a mini-itx board that can use the newest AMD processors, then I think someone will built a bigger PSU. You can always string together multiple PSU's to provide more 5V and 12V power.
Added: Here is some good reading. There is a section on PSU.
http://www.mp3car.com/vbulletin/faq-emporium/51489-attention-newbies-faq-faqs.html
Old 12-02-2006, 01:42 AM   #12
Ordered in two OPUS-250W, so I can gang them if required.
Still undecided on the CPU as yet.
Case, I might get a stock standard with the mini motherboard. I have access to a sheet metal facility. Mods\new one are not a major concern
I am stuck on the choice of hard drive..
1\ 2.5 laptop type,
2\Solid state 8 gig with a read only style boot up and shutdown (40 MB transfer rate)
3\Gigabytes GC-ramdrive, with extended battery life (bigger battery) and second boot option from 2.5 laptop harddrive if the first drive (ramdrive) fails.
Any advice appreciated
Old 01-05-2007, 06:09 PM   #13
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I'd read this thread regarding the solid state: http://www.mp3car.com/vbulletin/general-hardware-discussion/83012-solid-state-drives-boot-times.html
I'm considering the solid state drive myself in this next implementation.
Have you found a card reader that's capable of doing 40MB transfer?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 01-05-2007, 07:25 PM   #14
I am going to bite the bullet and get one of these that directly interfaces with the sata.
http://www.dvnation.com/nand-flash-ssd.html
Old 01-05-2007, 07:38 PM   #15
_
specifically which one?
Jan Bennett
Registration and hardware codes segerdahl StreetDeck 15 06-02-2007 08:51 AM
Update my first hardware (Serial Voltmeter).Add two new functions mauri Road Runner 43 10-31-2006 12:00 PM
Hardware Compatibility List - 800x480 Video Cards alfabob LCD/Display 13 10-10-2006 09:54 PM
Hardware kwiebe StreetDeck 0 10-05-2006 02:23 PM
Weird Registration Code and Hardware Code problem lookinco StreetDeck 2 09-30-2006 03:25 AM
