Old 11-19-2006, 04:20 PM   #1
soundfreak is an unknown quantity at this point
amp settings
hey guys i bought 800w amp kenwood and 2 12s mtx subwoofers
now can somebody tell me what are the best setings i can set on it
lpf.frequency now is at 80mhz
sensitivity is oround 0.5 max is 0.2
i set the filter at LPF`
bass boost is off
and is set on stereo
when i set bass boost on and put on lpf filter the bass are very loud but i heard bass boost is left off true? u got my settings there plz give ur opinion what do i set it on i want bass and clear sound
cd player Sony CDX-GT500 52x4
soundfreak is offline   Reply With Quote
Old 11-19-2006, 10:23 PM   #2
LaxPlaya8513 is on a distinguished road
set the amp to mono.... there are a BUNCH of different ways to tune your amplifier... I'll give you the easiest option, turn the gain all the way down so you can't hear your subs anymore... Turn your radio up until your speakers start distorting (or sounding like total ***), then turn your radio down so it's at 3/4 full volume. Then turn your subs up until they start distorting, and then turn it down 3/4 of the way...
That's tuning by ear, obviously that's not the ideal way of tuning. But for a novice who isn't looking for much, that's the best way of tuning it. Or you can follow the elemental designs method and download a test tone of 50Hz, play that looped and find the voltage you need for the amp to run at 800w RMS.
Then they're tuning by RTA, that is using a tool that measures certain frequencies and you adjust the subs to make a perfect flat line in the audio spectrum... that's usually professionals... i've personally NEVER done the RTA method before, i prefer using either the test tone or by ear
And btw, you actually should give the type of MTX subs as well...MTX is quite a large company and they DO make quite a few subs...
LaxPlaya8513 is offline   Reply With Quote
Old 11-19-2006, 10:53 PM   #3
ok i see one more thing when i turn bass boost with current setup my brake lights faint lil bit every time hard bass kicks in setup that i have now with out bass boost they dont and the sound is clear and it kicks nicely when i turn up obout 50% but when i turn up the volume to 70-80% its start to loose sound quality as u said distorting
Old 11-20-2006, 12:52 AM   #4
okay, so with the volume at 50%, turn your amp gain up until the subs start to distort, then turn them down 1/4 the way so that it's 3/4's of the way towards distorting...
Old 11-20-2006, 03:09 AM   #5
ok i see tx buddy
Amp running hot...?? Emerica2843 Car Audio 6 01-29-2006 08:29 PM
amp pop dan__wright Car Audio 6 06-16-2005 05:24 AM
Car Audio People, Help me pick an amp / Jeep GC w/ Infinety System hevnsnt Car Audio 3 12-07-2004 07:34 PM
Amp setup. Heat concern. d_sellers1 Car Audio 2 07-09-2004 10:58 AM
