The MP3car.com Store
Thread Tools Display Modes
Old 04-22-2008, 05:27 AM   #16
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (231)
Quote: Originally Posted by Sibi View Post
I just bought the live 24bit (because i had some problems with my audigy 2 nx) and i have a very big turn on thump when windows start (i think that my speakers will explode) so i went back to my audigy2 nx. do you have any solution to sugges so as to eliminate this turn on thump that i experience with the live 24 bit? (my power supply is the m2-atx and i arleady use the remote turn on of the m2 for my amp,i didn't have any turn on thump with the nx but with the live 24bit the thump is extremely loud and annoying).thank you.
Its not the card itself causing the thump. Its caused because your amps are turning on before the soundcard is. When the soundcard does finally turn on, its powering up causes the thump. I dont know what Power Supply you have but mine has a delay timer that turns the PC on, then the amps a few seconds later, eliminating the thump.
PS: I have a Sound Blaster Live 24 bit. My old CarPC had the thump even with the delay on because it took so long to activate the USB devices. My new system does it diffrently.
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Sponsored Links
Old 04-22-2008, 07:05 AM   #17
danielkh's CarPC Specs
danielkh's Avatar
Vehicle: 2004 Nissan 350Z
My Photos: (0)
I use the live 24 and this fix worked for me. You've probably already seen it though.
http://www.mp3car.com/vbulletin/mp3c...periences.html
my "procedure" is on post #30 (after the hardware is set up)
"Do not walk behind me, for I may not lead.
Do not walk ahead of me, for I may not follow.
Do not walk beside me either.
Just pretty much leave me the hell alone."
--unknown--
danielkh is offline   Reply With Quote
Old 04-22-2008, 01:45 PM   #18
HiJackZX1's Avatar
My Photos: (231)
Did you link to the wrong thread? This is for complaints on Mp3car's store.
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
Old 04-22-2008, 01:53 PM   #19
danielkh's Avatar
My Photos: (0)
Lol. My copy didn't work. Look on page 1 of this thread and I have a link their. Sorry about that.
Old 04-22-2008, 02:35 PM   #20
HiJackZX1's Avatar
My Photos: (231)
Its cool, I found it through the search. but this only works through the hibernation and stand by, what if i am starting from cold boot? I also found ampctrl, but on a UK site, it seems to have filled in missing documentation that the software creator left out. I think this is the better solution for me, but thats only if i can get it to work. i have 3 amps in my car, and my first CarPC install really suffured from pops.
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
Sponsored Links
Old 04-22-2008, 02:48 PM   #21
HiJackZX1's Avatar
My Photos: (231)
Ok, I have tried over and over to install it, but it will not let me do it. I think its because of the DOS version I have (DOS 5)
PS: Nevermind, I have the software installed. The instructions are terrible. I just have to test it on my amps now.
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
Old 04-22-2008, 06:51 PM   #22
danielkh's Avatar
My Photos: (0)
I drive 2 amps with no problem. By having the ampctrl program in the startup directory (did I not mention that), it works for cold start, then hibernate trigger and that kill command works for hibernation, shutdown, and standby.
And you are right.....that's how I figured out the batch files and all that other junk.....by trying it on my amps. Good luck!
--unknown--
Sponsored Links
vB code is On
Trackbacks are Off
usb sound card recommendations aletchet General MP3Car Discussion 2 11-29-2006 08:34 AM
Trust 5.1 External USB Sound Card 510EX, any good? FociMan General Hardware Discussion 0 06-26-2005 05:16 PM
External Sound cards and Ground loops - a survey Prem Car Audio 8 11-05-2004 10:30 AM
Sound Card on PCI rather than external legend5761 Car Audio 8 11-01-2004 06:05 PM
USB External Sound Card Recommendations Needed prospero Car Audio 0 04-27-2004 09:17 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
