I know there are USB sound cards out there with Anti-pop protection like the EMU 0404 USB card
http://www.emu.com/products/product....Specifications but it's way to bulky and only offers 4 outputs as opposed to min of 6, preferably 8.
The specs on the Gigaport are very thin, the so called 'datasheet' offers no more information than what the website gives. Almost looks like a pdf print of the website! Anyway, the manual does offer a bit more info and clears up some inconsistencies found on other websites in that it is a 16-bit card but with a 24-bit D/A Converter. It's also not USB 2.0.
For anyone interested, the specs are copied below from the manual from ESI website...
http://www.esi-audiotechnik.com/down...AG-English.pdf
1. Interface
- USB spec version 1.1
- USB audio class spec version 1.0
2. Output Type
- Analog 8 channel output (RCA jack)
- Digital 2 channel output optical mini jack
- Headphone output (3.5mm mini jack)
3. Analog Output Level
- -10dBV unbalanced
- -10dBV nominal
- +0.5dBV maximum
4. Analog Output Impedance
- 100 Ohm
5. Sampling Rates
- 32 hHz, 44.1 hHz, 48 hHz
6. Resolution
- 16 Bit
7. D/A Converter
- Dynamic range: 100 ~ 102dB A-weighted (typical)
- Frequency response: 20 ~ 22 kHz (@ fs=48 kHz)
- Resolution: 24 bit
8. Digital Output
- Type: mini plug optical connector, Toslink adapter included
- Format: IEC-958 Consumer (S/PDIF)
- Sampling rates: 32 kHz, 44.1 kHz, 48 kHz
- Resolution: 16 bit
9. Headphone Amplifier
- Output Power: 60mW maximum
- Signal to Noise Ratio: 110dB (typical)
- (THD+N)/S: -70dB, 0.03% (typical)
10. Power
- USB bus powered
- 250mA maximum
The search for a suitable usb sound card continues...
EDIT: Currently looking at the Audigy 2 NX from Creative.
