Old 12-14-2006, 12:16 AM   #1
asong31 is an unknown quantity at this point
Chevy Tahoe Stock Amp??
I drive a 2001 chevy tahoe and installed a system. I'm basically wondering if anyone knows where the stock amp might be located because I think if I can take that out it might solve my problems. Thank you for your time.
asong31 is offline   Reply With Quote
Old 12-14-2006, 01:02 AM   #2
Naamanf's Avatar
Naamanf is on a distinguished road
I think its under the center console. If you pull the bucket out I think you can get to it. No promises.
2007 Tahoe
Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
My Install
Naamanf is offline   Reply With Quote
Old 12-14-2006, 01:20 AM   #3
sfay93's Avatar
sfay93 is on a distinguished road
I didn't see any amp under my center console in my '01 tahoe. Are you talking about the amp for the rear sub?
ATVMS.com
sfay93 is offline   Reply With Quote
Old 12-14-2006, 01:21 AM   #4
Legarcondemerde's Avatar
Legarcondemerde is on a distinguished road
In an '01 it should be behind the glove box lid.
Legarcondemerde is offline   Reply With Quote
Old 12-14-2006, 03:34 AM   #5
Thank you guys very much. I will check it out in the next few days when I actually have some time again off work and see if I can solve my problem. Thanks again!
Old 12-14-2006, 01:35 PM   #6
Found stock amp...now..?
Ok, so I found the stock amp and then I thought, "ok, so now what?" Do I just disconnect it now? (I am running 2 amps, one for my subs, one for my front components, rear speakers are hard wired to the head unit itself.)
Let me attempt to explain my problem/set up:
Because it was difficult to run new wires from my head unit to my front components, I used the same wires that were connected to my original front stock speakers/tweeters. I still have the same stock rear speakers and I have that hard wired to my head unit, rather than having them plugged in thru the rca/amp (I'm not sure if I'm wording that right..). As mentioned earlier, I run 2 amps: 1 for my subs; 1 for my front components.
Problem:
At first, for a couple months, my system was working fine, never had any problems. But gradually I would have problems w/ both my front and rear speakers cutting out (so basically only the subs would be working) when I start my car. It got to a point where it'd be almost like a coin toss on whether my speakers would work or not when I start my car. On the few rare occasions that they DID work, once I tap the brake, or roll down my window, the speakers would just cut out right then and there. Now it seems as though they just dont work period. The amp seems to be fine; when I tried touching the wires for the component speakers to a battery to see if I could hear that "click" noise, I heard nothing. However, I think it might have something to do w/ the stock amp and would like to know what I should do with it (e.g. should I just disconnect it? Do anything special to it?).
Thanks again for your time.
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 02:45 AM
Stock hd-unit with aftermarket amp? schoo510 Car Audio 18 12-19-2006 07:17 AM
stock headunit + aftermarket amp possible? theheel Car Audio 10 09-11-2006 03:12 AM
New stereo install - input please, Which amp should I get? Anders Car Audio 10 03-09-2006 06:25 PM
Stock head unit (ford taurus) frostband Car Audio 14 12-26-2004 01:14 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
