The MP3car.com Store
Thread Tools Display Modes
Old 09-18-2007, 02:52 PM   #46
My Photos: (0)
Just finished wiring in my CD-UB100 hooked up to my DEH-P390MP. Using a 40GB 3.5" HDD in a USB 2.0 External enclosure powered by a 400watt AC/DC Inverter.
The unit works great! Except i cannot select next/previous tracks on the HDD. When you press Next/Prev it will skip to the next "song" however it doesnt start at the beginning of the song.
Its almost as if the UB100 is combining all of the MP3s into one huge song and when you press next/prev it skips xx seconds into the song and plays.
I couldnt get the unit to work with anything bigger than a 40GB HDD for some reason either.
Any input would be great.
ndboost is offline   Reply With Quote
Sponsored Links
Old 09-18-2007, 04:35 PM   #47
Vehicle: toyota/2007/tacoma
My Photos: (0)
It is going to come down the capability of your head unit I am affraid. Some have more features on them than others. Mine does everything that I could possibly hope for, it is great.
How are your folders set up? I have all of my albums in seperate files which might help.
tigerdongal is offline   Reply With Quote
Old 09-18-2007, 05:18 PM   #48
My Photos: (0)
Just one folder with all of the mp3s and wmas in the one folder. WHat head unit do you have?
Old 09-21-2007, 08:25 AM   #49
My Photos: (0)
Just bought a DEH-P6900UB and sold off my old head unit and the USB adapter. When i get this new head unit in i will test its functionality with a 160GB Fat32 HDD that has over 500 artists and 14k mp3s all categorized by Artist and then CD Name.
Old 09-21-2007, 11:22 AM   #50
My Photos: (0)
I have a 7900 BT and it works perfect. Displays all the info that I need. My drive is partitioned to 30 gigs and will have around 500 folders in it by the time I am done. I could put it in the other way where it just lists tracks and I would have 15k capacity but it would not be nice and neat and play the way I want it. Also I have a 4 gig jump drive and I may go to a 16 gig stick when the prices come down enough. Currently waiting for Simpletech to send me a replacement Y usb cable as mine died during the install. It will not read the drive with a longer cable! Unless you have aux power to the drive. Weird but I want mine without additional power supplies.
Sponsored Links
Old 09-21-2007, 03:17 PM   #51
My Photos: (0)
the head unit supports m3u playlists as well. So you can have them all in 1 folder and just organize the play lists. I need to get a 2.5" HDD but ive got over 100GB in mp3s and the whole reason for this was to eliminate the need for cd's. So ill have to have my entire music collection, or nothing.
Funny thing is the new head unit cost the same as my old head unit + the UB100
Old 09-21-2007, 06:24 PM   #52
My Photos: (0)
There is a chance that you might need to have 2 hdd for your music. My current setup doesn't have anywhere near that amount of music!
Old 09-22-2007, 10:33 PM   #53
My Photos: (0)
Ill know Tuesday after work, should have the head unit by then. Already got the harness made up, just need to click in and go
Old 09-24-2007, 08:26 PM   #54
My Photos: (0)
phone connection
I have an Avic z1 and the pioneer rep said I can connect my Motorola q9m with the CD-UB100 to play music from the phone thru the head unit. Anyone try connecting their phones this way to see if it works? Ultimatly I'm looking to stream internet radio since there are thousands of channels. any help would be appreciated
chilli0007 is offline   Reply With Quote
Old 09-24-2007, 08:29 PM   #55
My Photos: (0)
It all depends of the format of your phone I suppose, but trust me Pioneer don't normally know what their products can do. I was on the phone arguing with their helpline about the usb-100 losing its memory when powered down, they said it does that. Bull!!! It was wired wrong by my installer, has to be live always. So don't believe everything they say, might be right but could well be wrong. U could try it from crutchfield and if you have no luck send it back.
Old 09-24-2007, 08:37 PM   #56
My Photos: (0)
thanks for the quick reply. I'm not sure how to check the format, I know the internet radio stations are usually in asx format not mp3. I don't know if the headunit or CD-UB100 will even recognize it.
Old 09-24-2007, 08:44 PM   #57
My Photos: (0)
Another good example is my MP3 Player, Zen Vision. It won't read it because the format is different. It has to be fat32 the old windows system before NTFS came along. Now I have a 4 gig flash and a 60 gig external that I may use for a while until the 16 gig sticks come down!
Old 09-27-2007, 10:29 AM   #58
My Photos: (0)
I've tried 3 USB sticks so far and none of them worked Here's what I found though, the P-Bus cable has one ends coloured BLUE, the other end is BLACK. I have the BLACK end hooked to the headunit, the BLUE end is connected to the OUT port of the CD-UB100. Is the cable directional?
After I read through the thread, I seem to have the cable connectors reversed. Can anyone confirm?
Thanks for your help.
htsource is offline   Reply With Quote
Old 09-27-2007, 10:38 AM   #59
Vehicle: 1991 Chevy Suburban 1500
My Photos: (0)
You may not have the cable itself reversed, but you may have the port on the USB adapter backwards. I know when I hooked up my cousin's Ipod adapter on his Pioneer, I put it in the wrong one (dont remember which was wrong and which was right). What it did was everything seemed to work perfectly control-wise, but I didn't have any audio. Switched to the other port on the adapter and I got audio. So, the audio is directional to the ports, control data is not, it's just passed through.
Crawdaddy is offline   Reply With Quote
Old 09-27-2007, 11:10 AM   #60
My Photos: (0)
Initially, I plugged the P-bus cable into the "IN" port on the USB adapter, now I switched it to "OUT" port, still NODEVICE from headunit.
Sponsored Links
vB code is On
Trackbacks are Off
EnGenius EUB-362 Wireless Wifi USB Adapter Review L-U-R-C-H The Review Palace 22 09-10-2007 09:21 AM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 11:49 AM
self powered or bus powered for USB wifi adapter jagsnag Wireless Communications 1 07-28-2005 06:49 PM
802.11G WiFi Adapter -- USB, Cardbus, CF, or RJ45 Ethernet? Bailey Wireless Communications 9 01-22-2005 11:33 AM
USB to ide adapter + Toshiba laptop dvd drive carprowler General Hardware Discussion 2 06-24-2004 11:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
