Old 01-09-2007, 05:08 PM   #1
E46M3 is on a distinguished road
Exclamation CarPC + Alpine H701 = No Sound
Hi everyone,
I'm stumped... if someone can help me I'd appreciate it...
Current Configuration:
I have a VIA Epia Sp13000 Mobo, I'm using the SPDIF out to Tos Link into H701
I have enabled the SPDIF feature by changing the jumper switch on the mobo & via software.
I have also selected the input Setting of Digital 2 on the H701 via teh CUX controller.
I'm not getting any sounds at all... can somone help me?
E46M3 is offline   Reply With Quote
Advertisement Sponsored links
Old 01-09-2007, 05:20 PM   #2
audio configuration pic
Old 01-09-2007, 05:35 PM   #3
nvm fixed... bad optical cable
Old 01-09-2007, 05:35 PM   #4
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
have you updated the drivers? there is also a link to a how-to somewhere on this forum. do a search, i ran into the same problem, it's an easy fix but you do need the correct drivers and some other app.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 01-09-2007, 05:37 PM   #5
MySQL Error
scott_fx's Avatar
or that
M10k
My Car Pc Install
Old 07-11-2008, 06:25 AM   #6
DrLove is an unknown quantity at this point
Hi, I have converted the optical in on my H701 to coaxial, I just removed the optical to coaxial converter on the H701 and feed the H701 w/ coaxial digital directly, works great w/ SB x-fi PCI card but not w/ the onboard digital out of my EPIA board, no sound at all. U are talking about a solution above, can U help me? Maybe I'm doing something wrong, I would love some help here.
DrLove is offline   Reply With Quote
Old 07-11-2008, 08:57 AM   #7
FPeter's Avatar
FPeter is an unknown quantity at this point
two small thing:
1. voltage level conversion might solve your problem with integrated sound, the signal's strength might not enough for the receiver
(Coax to TTL)
2. if you connect directly the spdif signal from soundcard to the receivers pin, this can cause groundloop and noise problems. an 1:1 line transformer is the best solution between them...
Intel D201GLY, 512MB DDR2, Samsung SP1213N 3.5" 120/7200/8M HDD, audio through digital line
bye bye noise - the DIY S/PDIF DAC
FPeter is offline   Reply With Quote
Old 07-11-2008, 11:19 AM   #8
psychotic is an unknown quantity at this point
quick question... since you can use optical from carputer to H701, and basically have the H701 as close to the amplifier as you want.... does this mean almost 0 chance of ground-loop from running a long RCA cable from front of car to back among all the car's electrical?
psychotic is offline   Reply With Quote
New Chip Provides High-End Sound DarquePervert Car Audio 8 12-06-2006 11:58 AM
Sound cards from incarpcs , sacrificing sound quality? skinhead General Hardware Discussion 15 09-02-2004 03:05 AM
How does this sound (no pun intended ;) SpeedFreak03 General Hardware Discussion 10 06-16-2004 06:49 PM
3 Sound related questions for CarPC nirvanades General Hardware Discussion 1 05-31-2004 09:04 AM
Alpine / PC Challenges all around... acitrano General Hardware Discussion 5 11-10-2000 08:45 AM
