Quote: Originally Posted by
reggiek945
I just found out how to get the optical in and out to work at the same times with the Roadie using RoadRunner. I was fustrated that this option wasn't there when in fact it is. Fist in the rr config under xm/serrius, select use Line-In-Plug-in. Save the goto the turtle beach control panel, select mixer. Under record settings select SPDIF In. That should be it. Make sure that under speakers you have either s/pdif out 44.1khz or 48khz out. I hope this helps!
Reggie
I had literally shelved my Car PC and given up on them in general, having determined it just isn't worth the hassle, and along comes your post. Thanks for the info - if this works, it may just make it worth giving it another go, as that was my last hurdle. Thanks again, I will give it a shot!
