Quote: Originally Posted by
GoHybrid
Quick question... seemed logical to me, but the clip light on an amp is pretty much just detecting DC in what should be an AC signal and lights up whenever it sees it, right?
If that's the case, then the clipping indicator should light whenever a signal is clipped, regardless of it's origin or gain right?
the question boiled down to real world terms is that my amp has a clipping indicator and I can turn up my head unit to the point just before it clips, but i can crank my onboard sound all the way to the top... and no clipping indication. So, either i'm wrong in my assumption about how this works, or i can actually output a clean signal at full volume from my mac.
Anyone want to sound off?
In your amp I am sure the clipping indicator is just a voltage comparator. When they designed the amp they know how much input voltage it can take. They then probably built a circuit to monitor the voltage level. If it ever goes over the light turns on. It won't really know if the AC is turning into DC. That is my best guess because I doubt they took any more time designing that feature, otherwise they would have gone for a limiter/compressor circuit instead.
From what I have seen, without any boosting of bass/treble/EQ adjustments over 0db, then you can turn the volume all the way up on the soundcard without clipping.
